PARTS for SALE
Device Name Function
ADC08831 8-Bit Serial I/O CMOS A/D Converters with Multiplexer and Sample/Hold Function
ADC08832
CD40106BE CMOS Hex Schmitt Triggers
CD40192BE CMOS Presettable BCD Up/Down Counter (Dual Clock with Reset)
CD4019BE CMOS Quad AND/OR Select Gate - 10
CD4021BE CMOS 8-Stage Static Shift Register
CD4059AE CMOS Programmable Divide by N Counter
CD4072BE Dual CMOS Dual 4-Input OR Gate
CD4078BE CMOS 8 Input OR/NOR Gate
CD4094BE CMOS Programmable Divide by N Counter
CD4510BE CMOS Presettable BCD Up/Down Counter
CD4520BE CMOS Dual Up Counters
CD4536BE CMOS Programmable Timer
CD74AC20E Dual 4-Input NAND Gate - 10
CD74AC541E Octal Buffer/Line Drivers -10
CD74ACT374E OCTAL D-TYPE Flip-Flops - 10
CD74ACT86E Quad 2-Input Exclusive-OR Gates - 8
CD74HC390E Dual Decade Ripple Counter - 10
CD74HCT21E Dual 4-Input AND Gate
CD74HCT365E Hex BUFFER/DRIVER TRI STATE - 9
CD74NC4050E Hex None-Invert BUFFER -
CLC420
CLC5632IN Dual, High Output, Programmable Gain Buffer
CLC520
CLC5633IN
LF347BN
L293DNE Quad HALF-H Driver
LM1084-5 5A Positive Regulator
LM1084-12
LM1086-2.85
LM1283N 140 MHz RGB Video Amplifier System with On-Screen Display (OSD)
LM1585-ADJ
LM1894N Dynamic Noise Reduction System
LM19
LM1971N Audio Attenuator w/ Mute
LM231
LM2825HN-ADJ Integrated Power Supply 1A DC-DC Converter
LM285LP-2-5
LM2917
LM2940CT-5 1A 5V Low Dropout Regulator
LM2940T-5 1A 5V Low Dropout Regulator
LM331
LM334
LM336BLP-2-5 2.5 V Reference
LM347
LM35DT
LM360
LM380
LM385BZ-1.2 Micropower Voltage Reference
LM385LP-2-5 2.5 V Precision Voltage Reference
LM386
LM3914N-1
LM4651N 170W Class D Audio Amplifier Solution
LM4765T
LM567
LMD18200T
LMS1585ACT-ADJ LDO Fast Response Regulator
LMS1585AiT-ADJ LDO Fast Response Regulator
LT1004CLP-2-5 2.5 V Micropower Voltage Reference
MAX232CPE
MAX232ACPE
MAX233ACPP
MAX233EPP
SN74ACT373N OCTAL D-TYPE TRANSPARENT LATCHES WITH 3-STATE OUTPUTS - 10
SN74ACT533N D-TYPE TRANSPARENT LATCH - 9
SN74HC165N 8 Bit SHIFT REGISTER - 20
SN74HC266N QUADRUPLE 2-INPUT EXCLUSIVE-NOR GATES WITH OPEN-DRAIN OUTPUTS - 4
SN74HC367N Hex BUFFER/DRIVER TRI STATE
SN74HC682N 8-BIT MAGNITUDE COMPARATORS - 7
SN74HC688N 8-BIT MAGNITUDE COMPARATORS - 10
SN74HC7002N Quad NOR Gate - 10
SN74LS221N Dual monostable multivibrators with Schmitt-trigger inputs -
TL497AIN Switching Voltage Regulator
TL750L05CKC 5V 150mA LDO Regulator
TLC0831
TLC7725
TPIC6C596N 8 Bit SHIFT REGISTER
TPS6755IP Adjustable DC/DC Converter
UC3903N
UC3946
UC3770BN
UC3717AN
VFC32KP
ULN2003AN
MANY OTHER IC's AVAILABLE LIKE RTC's and Temperature compensated crystal oscillators.
THANKS.
IC ADC 0831 / IC TLC0831 - 8 Pin DIP
I need IC TLC 0831 / IC ADC 0831 ( 8 Pin DIP ) Qty : 50 Nos
Pls send me a quote.
Sulax[/quote]
