Parking guiding system
laxmid
As i am doing project on this
RFID, PIC-16f877, 3 sensor for parking
const unsigned char card1[] = "1D00E4018971";
const unsigned char card2[] = "1A003E2C5850";
const unsigned char card3[] = "1A003E772A79";
void read_card_value_from_uart() // Rxing card_value from rfid
for(k=0; k<=13; k++)
read_card_value[k-1]=getch();
rxed card_value from rfid should be compared with card1,card2 , card3
if any one card matches with rxed value it should display the corresponding card user on lcd otherwise it should display as unautherisd user.
for this i wrote function as
void compare_cards()
if((strcmp(card1,read_card_value))==0)
lcd_clear();
lcd_goto(0);
lcd_puts("card1 user");
else if((strcmp(card2,read_card_value))==0)
lcd_clear();
lcd_goto(0);
lcd_puts("card2 user");
else if((strcmp(card3,read_card_value))==0)
lcd_clear();
lcd_goto(0);
lcd_puts("card3 user");
else
lcd_clear();
lcd_goto(0);
lcd_puts("Un-Autherised user");
for im getting o/p as "unautherised user".
plz check the function let me know.
That means your "read_card_value" doesn't read the card values properly.You can verify is your "read_card_value" gives the proper unique code by sending the "read_card_value" directly to the LCD without comparing.
Why are you doing this? On the first time through the loop you then have:
read_card_value[-1]=getch();
Just use:
void read_card_value_from_uart() { // Rxing card_value from rfid
	for(k=0; k<=13; k++) {
		read_card_value[k]=getch();
heh also your arrays are wrong:
Are supposed to be 13 byte arrays i assume...You are supposed to have 13 bytes in it now 13 characters like this would be it more or less but your missing bytes then:
const unsigned char card1[] = {0x1D,0x00,0xE4,0x01,0x89,0x71};
const unsigned char card2[] = {0x1A,0x00,0x3E,0x2C,0x58,0x50};
const unsigned char card3[] = {0x1A,0x00,0x3E,0x77,0x2A,0x79};
As you can see there is infact only 6 bytes in this... If the string is exact and contains those 13 characters you might mean this then:
const unsigned char card1[] = {0x01,0x0D,0x00,0x00,0x0E,0x04,0x00,0x01,0x08,0x09,0x07,0x01};
const unsigned char card2[] = {0x01,0x0A,0x00,0x00,0x03,0x0E,0x02,0x0C,0x05,0x08,0x05,0x00};
const unsigned char card3[] = {0x01,0x0A,0x00,0x00,0x03,0x0E,0x07,0x07,0x02,0x0A,0x07,0x09};
Thanx to all for ur kind reply.
Actually "read_card_value" doesn't read the card values properly. Thats the i was getting 1st value its taking dummy then after 12 numbers its taking again 2 dummy variable. for that reason i was getting problem.
i have completed this project.
Thanks to all.
If you know please tell me how to interface keyboard to pic16f877a?
n how it works?
as i am using 6-pin ps/2 connector. Please help me out as arly as posible.
Thanks in advance.
PS/2 isnt hard nor easy heh. I have code somewhere on the forum for it.I need to redo a new one tho. Just to clean it up since i feel smarter now maybe i can make it better heh
