Parallel slave port
viks_raj
Hi guys
I am sending data from 16C773 to 18f4580 using PSP.
I am posting part of code using PSP ,can you tell me what is wrong here.
   org 0x0000
;************ initial *******************
   goto start
              org 0x0018
              goto int_serv
start
    banksel    ADCON1
    movlw      0x0F
    movwf      ADCON1
    movlw      0xff          ; All Port D pins are inputs
    movwf         TRISD          ;
    CLRF       PORTD
    movlw      0x17
    movwf      TRISE
    movlw      0x00          ; All Port C pins are outputs
    movwf         TRISC          ;
    CLRF       PORTC
   banksel      INTCON
   clrf       INTCON
   movlw      0x80
   movwf      PIE1      ;enable Parallel Slave Port
.....Do some stuff here.
int_serv
                banksel PIR1
   btfss PIR1,PSPIF
   goto nothing
   bcf PIR1,PSPIF
   banksel TRISE
   btfss TRISE,IBF
   goto nothing
   movf PORTD,W
   movwf PORTC
nothing
   retfie
   end
I assume this code is for the PIC18F4580 chip.
To use location 0018h as interrupt vector, you have to enable the interrupt priority feature by setting bit7 of RCON. Then you also have to set bit6 of INTCON (GIEL) to enable low priority interrupts. Ensure that PSPIP bit is cleared.
BTW on the PIC18 family, banksel is not required because all the special function registers are located in the access bank.
On the interrupt service routine, you can avoid using the WREG register by using the instruction:
    MOVFF PORTD,PORTC
Then you don't have to worry about context saving during interrupts which was omitted in your code.
Lastly, this looks like code orginally coming from a PIC16 family. With the PIC18 family, the BRA is an optimum instruction over the GOTO because you aren't jumping too far.
    MOVFF PORTD,PORTC
Or you can use
retfie fast
Instead of retfie itself. This will take care of saving Wreg, BSR, and STATUS registers.
I recommend you to use 0008h Interrupt vector instead, therefore you don't hava to "play" with setting interrupt priorities:
Thanks alot both of you.
I will surely make changes today and post result here.
Please have a look later.
thanks once again.
I have tried both Low priority and High as well.
Means 0008 and 0018 both.
but no result.
Due to some reason my 16C773 is not able to give generate interrupt for 18f4580.
Although I have tested CS and WR ,these signals are OK.
and data is also there on PSP lines.
but then also interrupt is not generated.
I am giving pulse of 30 micro sec on WR and CS.
Is it OK ??
