Optical rotary encoders and Schmitt triggers
atferrari
Most Helpful Member
Optical rotary encoders as in PC's mice to be read through two PIC's pins.
Schmitt triggers in between, are they convenient? Or a must? Or not necessary at all?
In my experience the schmitt is a must.
Otherwise the slow rise time of the signal while the photo-interupter passes through the light beam, combined with a bit of noise on the signal, can cause all sorts of problems.
I go with JimB on this one, I have always found most optical encoders have slow rise times, use a Schmitt.
A software solution sounds attractive, but long debounce delays are required to ensure they covered the worst case encoders.
E,
Sensor output
This is what the ST will have to deal with: output of one of the sensors obtained while turning de encoder's disk slowly back and forth.
What I would have expected.
As I said, Schmidt it.
