operational amplifier input current
aiva
Hi to all!
I have got the small question.
Whether the operational amplifier entrance voltage influences an input current? And how strongly does it influence?
Thanks.
The input transistors in opamps are fed from constant current sources and sinks so the input bias current doesn't change much when the input voltage is changed.
The bias current can be nearly 10 times higher for one opamp that is the same as another, and the bias current changes a lot with temperature change.
Use a FET-input opamp if you worry about bias current.
