One Wire Communication.
jjd
What's the easiest way to communicate through one wire (and ground)?
I need to send two bytes between boards.
I only have one wire to do it. Is it possible to put a transistor between the RX and TX to cut RX off when TX is sending?
You could do it as a master slave. When the master sends a command via hardware, then receive back via a software (bit bang)
The picture is an I2C converter circuit, should work.
In your diagram, what's to stop the TX signal from going into RX during transmission?
