Epyontronic
I need help finding equivalent parts to repair my Odometer to one of my cars. So the problem was that the Odometer display wouldnt show, stopped working. Everything else on the gauge cluster worked. When I took it apart, C3 Capacitor was blown. I went ahead and replaced the surrounding Capacitors being 10uf/50v as listed below. Plugged everything back in and still nothing. So I took apart again and checked all connections, all the surface mount chips had good connections. I checked the below described diodes and transistors. Used my desolder gun to remove them and check with meter as they looked corroded and two of them pretty much crumbled when removing (the leads that is). So now I am stuck needing replacements.
So this was taken from another forum. I need to know TR6, DA1 and DA2 (in red lettering below) equivalent replacements. This is for a 1993 Mazda RX7 car. This is the only information I have, so i dont know any more about the diodes and transistors.
Capacitors (Values shown)(Temp on all Caps: 105*C)
C1: 10uF, 50V, DigiKey P/N: 493-1890-ND
C2: 47uF, 25V, DigiKey P/N: P5539-ND
C3: 1000uF, 6.3V, DigiKey P/N: P10199-ND
C4: 1uF, 50V, DigiKey P/N: 565-1332-ND
C5: *Surface mount device on backside of board*
C6: 1uF, 50V, DigiKey P/N: 565-1332-ND
C7: *Surface mount device on backside of board*
C8: *Surface mount device on backside of board*
C9: R33 (line 1) BP (line 2), 50V, *P/N search suggests 33uF*
C10: *Surface mount device on backside of board*
C11: 2.2uF, 50V, DigiKey P/N: P13462-ND
C12: 10uF, 50V, DigiKey P/N: 493-1890-ND
C13: 1uF, 50V, DigiKey P/N: 565-1332-ND
C14: *Surface mount device on backside of board*
C15: 0.015uF, 50V, Mouser P/N: 80-MMK5153J50J01TA18 *CAUTION: Refer to Post #25!*
C16: 2.2, 50V, *Need capacitance value, could be uF or pF*
C17: 1, 50V, *Need capacitance value, could be uF or pF*
Resistors:
R10: 20Ω, 5% Tolerance (stamped 20ΩJ)
R18: 20kΩ, 5% Tolerance
R25: 10kΩ, 5% Tolerance
VR: 200kΩ, Digikey P/N: 3306K-204-ND, manufacturer P/N: 3306K-1-204
Integrated Circuits:
IC1: 744C14A
IC2: TA78DS
IC3: 93C56EN
IC4: L2903 *not 12903 from the photos*
IC5: D75108GF(A)
IC6: AN8363UBK
IC7: M6544
Power Transistors:
TR1: D1922 (line 1), E (under last 2)
TR2: D1922 (line 1), E (under last 2)
TR3: G8 (device is very small, next to ZD6)
TR4: B1217
TR5: C458 (line 1), D (line 2), 3D1 (line 3), Google " transistor 2SC458"*
TR6: A143 (line 1), X.SZ (line 2)
TR7: C144 (line 1), ESZ (line 2), Google this P/N NTE123AP*
TR8: C144 (line 1), ESZ (line 2), Google this P/N NTE123AP*
TR9: C1214 (line 1), C (under last 4)
* - Search on Google resulted in transistor for purchase on other sites (not DigiKey or Mouser Electronics).
Diode Arrays:
DA1: P209 (line 1), S. X (line 2)
DA2: DA218
Resistor Arrays:
RA1: *Not Installed*
RA2: E10kΩ39, *Implies 10kΩ resistance)
Crystal:
XTAL: 4190A (line 1), 3N2 (line 2)
Diodes:
D1: *No markings*
D2: *No markings*
D3: *No markings*
D4: *No markings*
D5: *No markings*
Zener Diodes:
ZD1: *Illegible*
ZD2: *Illegible*
ZD3: *Illegible*
ZD4: 1N4742A, DigiKey P/N: 1N4742AFSCT-ND, Radio Shack P/N: 2760563
ZD5: 5 *Partial*
ZD6: PZ627
ZD7: *Illegible*
ZD8: 3 *Partial*
ZD9: 3 *Partial*
ZD10: 30 *Partial*
Thanks,
Brent
Resistors:
IC1: 744C14A
IC2: TA78DS
IC3: 93C56EN
IC5: D75108GF(A)
IC6: AN8363UBK
IC7: M6544
Power Transistors:
TR4: B1217
Diode Arrays:
DA2: DA218
Resistor Arrays:
Crystal:
Diodes:
D1: *No markings*
D2: *No markings*
D3: *No markings*
D4: *No markings*
D5: *No markings*
Zener Diodes:
ZD1: *Illegible*
ZD2: *Illegible*
ZD3: *Illegible*
ZD5: 5 *Partial*
ZD6: PZ627
ZD7: *Illegible*
ZD8: 3 *Partial*
ZD9: 3 *Partial*
ZD10: 30 *Partial*
Thanks,
Brent
20170316_131253a_cb96c26e0b5f472468ac08d30cf4934776301b42.jpg206.2 KB · Views: 132
20170316_133828a_256699e3c389cb9f8b130b574f4942bd7b757fc1.jpg262.5 KB · Views: 149
20170316_133844a_0696fbbd83bf9e71d9af723e374ba8120151e93a.jpg209.9 KB · Views: 141
20170316_133912a_5a8087cfce122a0a2ceee81f6415c32c0518c0ee.jpg208.5 KB · Views: 139
20170316_183409a_0fc095278df5d160ef2de27c13b0b259418aa405.jpg236.3 KB · Views: 136
