I realise I post semi-random questions, rather than specifics about jobs, and this is no different, but I have googled this one and only come up with high power 'DC-AC', 12V to mains converters, often dangerous and poorly engineered ones
I have a guitar multi effects that uses an AC 9V (2.2A) power supply brick (essentially, just a transformer and fuse in a box). Its rather big and heavy so as a challenge - as opposed to something that 'needs' to be done - I thought I would attempt to build my own converter allowing it to run off a DC input with a voltage range, so I can use any old SMPS wall-wart with sufficient current capability (and voltage output).
Now, often AC devices that use SMPS just rectify the input straight away, so will run off DC, or an ugly squarish wave at a higher frequency than mains. But this unit has an interesting power supply on board - it uses a voltage multiplier for ~60V for a vacuum tube, and capacitor/diode doublers going to voltage regulators, both come straight off the 9V AC input. So, DC is out (don't want to modify the internals). Given its an audio device, even with its internal filtering I'm cautious about audio-band noise being introduced to it, soo.. whilst I don't need a 'pure sine wave', something without massive harmonics would be nice.
Would a PIC loaded with a sine-wave table, using PWM to drive a H-bridge be sufficient? Its so much easier to just 'buy another transformer' but its the size and weight I'm trying to avoid. And because its only 9V (I assume thats RMS) I think I can get away without a transformer, just a large filter/common mode choke on the output to suppress the PWM switching frequency.
If anyone has actually built a DC-AC inverter (any power) I would appreciate your input. It does look like it can get incredibly complicated but given the low voltage, relatively low current, and slack sine-wave requirements, I'm hoping I could get something with parts I already have (swimming in parts here..). And then there is the question of regulation. Any idea's?
