Regarding an SMPS with just a two wire feed (go and return), it is a fact that generally a non-isolated design will give a lesser common mode noise problem than an isolated design.
Why is this fact not stated anywhere, in any book or website?
Bottom of page 2 (2nd paragraph up) of this document
https://www.ti.com/lit/an/snva489c/snva489c.pdf
Says that ….
QUOTE
In a typical IC based non-isolated DC-DC SMPS, only two lines connect to the input port. So any current going in through one terminal has to go out through the other. In this configuration, the common mode noise VCOMM will always be zero.
UNQUOTE
This is simply not true. Even a two wire non isolated SMPS can radiate energy into its surroundings and thus the “go” current will not equal the “return” current.
Says that ….
QUOTE
UNQUOTE
