Nichrome Amp Calculation???
SMUGangsta
Hi
Just a quick one,
I am trying to figure out the current used by my nichrome wire.
Is is 50Ω per 1000mm (1m) - is this a normal ohms law thing?
im using 30mm
V=I×R
so re-arranged to find I would be
I=V/R
I = 12v/1.5Ω
So the nichrome draws 8Amps as a heating element. <<<is this right?
Will the resistance of the wire change as it heats up, I would like to switch it with a 10A relay.
Your calculation is correct, but 8 amps is 96W which would likely melt a 30mm wire (you have a fuse). Estimating that you wire is 34 gauge, I believe you should limit the current to about 2 amps.
The wire will increase about 6-10% in resistance as it heats to a red heat.
Hi
Just a quick one,
im using 30mm
V=I×R
I=V/R
I = 12v/1.5Ω
Yes, 30/1000 = 3/100 = 3% of 50Ω = 1.5Ω.
The resistance tempco of Nichrome is pretty low.
If this skinny wire is inside a 1/4" metal tube embedded in ceramic, or under water, it can dissipate quite a bit of power.
