New to pic programming
TKS
Hi all,
i need the following stuf and fast..
-Programmer board (hope 1 in circuit :D ), where to buy
-know how to make a chip choise
-knowing how to know how much chips you need
-knowing how to convert basic lang to assembly
- or how to learn quick assembly (books)
i have reserved for all this 450euro's
TKS
p.s. its no problem to buy a program board but then i need the scheme form it could copy it easyli
p.s. 2 i a pic or atmel chip the same as a ordinarry 386 chip???
and what whould i buy if i wanted simpel
a cpu and some mem and some i/o chips..??
:D
i would like complete projects example because the working of it is already proofed
Take a look at nigel's site
www.winpicprog.co.uk , if offers the scematic for a programmer (P16pro40) and free windows software and tutorials to learn assembler.
secondly www.microchip.com , the home of the pics offers a bunch of information.
A google search on 'Pic projects' gives a lot of usefull hits also.
A pic is NOT the same as a 386 chip, in fact, there a totally diffirent breed. The x86 is a microprocessor, a 'number crunsher' it is only a processing unit with a memory and databus, it relies on other components to do the actual I/O adn storage of data.
A pic is a complete computer on a single chip, it has ROM (or flash), RAM, rocessing unit, I/O, all on chip, so no external parts are required (except for a oscillator). As a result, it isn't nearly as powerfull as a 386 but it doesn't need to be, as it will spend it's life doing simple controlling functions, not running windows :P
Choosing archtecture
Hi thanks for your reply,
OK, i wanne bluid a SEFI system
(Syquential, Electronic, Fuel< Injectionsystem)
for a 6 cylinders engine.
that means for every time y inject the fuel i have to calculate the amount of fuel that is required.
I/O list:
inputs:
-water temperature
-air temperatue (maybe calculated)
-air density (maybe calculated)
-air weight (maybe calculated)
-rotation freq of the crankshaft
-camswitch (6x)
output:
a example of it:
Continue EFI
outputs there are offcourse also:
-6x injector
-6 outputs for a LCD ??? (if it is possible)
-serial i/o whit the pc
i also wanted to have the possebilety to watch/debug online???
TKS
(i started in de pic world whit a oopic system it worked very fine but i think that architecture cost a lot of performance..)
but the software was fine for it..
