neeed help
5 pins when you include the power pins. Most op amps are like this so you shouldn't have any trouble finding one.
4 pins minimum
[1]Input
[2]Output
[3]V+
[4]Ground
hotwaterwizard said:
4 pins minimum
[1]Input
[2]Output
[3]V+
[4]Ground
It wouldn't really be much of an opamp if it only had a single input - it would have to be an opamp pre-wired to a particular configuration in which case I think the overall device would be called by a different name - buffer, amplifier, etc.
4 pins minimum
[1]Input
[2]Output
[3]V+
[4]Ground
Four pins?
I can't see an op-amp on the site you linked with only four pins.
I don't see how it's posibble to have an op-amp with any less than four pins.
There is no such thing as a three legged op-amp but you can find the kind with five or more legs over on www.google.com.
