need to explain !!
XL-power
hi all
i write a program in order to move a servo motor according to an Accelerometer ....and yes the motor moves while you are change the direction of the accelerometer but ... i face a problem that the servo sometimes moves free whithout touch the accelerometer
is there any thing wrong?how can i control the servo motor so that it moves according to the movement of the sensor only ...
my circuit : accelemeter >> microprocessor>>relays>>servo motor
thanks in advance
You have provided no code, no information about the devices you're using, and no circuit, there is absolutely no way to respond to this post because you didn't provide the proper information.
you better post your schematic + more info. Check whether you have given the correct frequency to the servo. They tend to vibrate if the inputs are out of range.
um i would recommend not reading or moving the servo until somewhat large motion is detected. Like you are most likely moving the servo on any motion sensed. What you can do have a calibrated state. Like read the acc then have that state as 0 so when it changes you will know.
Do you understand?
