As a science project, I am planning to build a device to count alpha particle hits. The device works by ionization. (please see
) There is a high voltage DC power source. Negative side is a metal mesh. Positive side is a copper plate. Between them there is a space of 1/3". When an alpha particle (such as those emitted by Americium from a smoke detector) hits the arrangement at a right angle from the mesh side, it ionizes a path in the air between anode and cathode, bridging the gap and causing a discharge between them.
I need to very accurately count those discharges over periods of several hours by means of a digital counter (such as those you can buy over Ebay). The counter should be able to be activated by each individual high voltage discharge. Therefore I need a method of making those discharges safely activate a switch that would make the digital counter advance one unit for each discharge.
My budget is very limited. I'd appreciate some input from our experienced community. Thanks in advance.
