davepusey
Circuit:
Explanation:
Pin 2 of the PIR connector is the open-collector output. This pulls to ground when motion is detected, turning on PNP transistor Q3, which in turn produces an active HIGH signal at "TRIGGER".
This is then used to switch two on NPN transistors (T1 and T2).
T2 produces the LOW pulse for the 555 trigger pin to start the timer.
T1 shorts the timing capacitor C2 to ground, making the the time delay start from the most recent trigger pulse.
During the time delay, the 555 output turns on N-Channel MOSFET Q2, which illuminates the LED lamps.
Problem:
All of this works perfectly, except for one minor annoyance which I cannot figure out how to solve.
When a trigger pulse is present, the voltage at the Drain pin of Q2 rises by 25mV - measured on my DSO. While this doesn't seem much, it is enough to cause a visible dimming of the LED lamps.
The only way I have found to resolve this is to remove R4 and LED1 from the circuit.
R4 and LED1 are used to visually indicate the trigger pulses from the PIR sensor, which I would prefer to keep in the final circuit.
Explanation:
Problem:
