Hi Everyone.
I am trying to create a simple board design for a keyboard matrix using metal domes as switches.
The schema is easy enough, i first created a custom library which was essentially wire for the outter ring (contact) and a pad for the inner contact.
see image
I then found someone elses library for omron's dome keys which is made of smd for the outer contact and a pad for the inner contact
see image
in both cases,
the outter contact or ring is attached to the rows and the inner one on the (2nd layer) back of the board.
Now. come the questions.
1) which of these libraries is correct the smd + pad one? considering i want to make a double sided board.
2) how do i draw the board. i have drawn the top layer by connecting all outter rings per row and the bottom layer by connecting all the inner circles by column using the wire tool,
3) am i correct in saying that i need vias and i need to make them in the board design tool and not in the library itself?
4) or do i just need to draw a hole.
the biggest issue i am not sure about how to solve is that regardless of smd or wire, how do i make sure both sides are correct and how do i add the via.
You can probably sense i am quite a noob. any help is appreciated. if you need more info or pictures let me know.
thanks.
see image
see image
in both cases,
thanks.
