Post a schematic of the circuit you used and we may be able to help.i use a triac in flyback converter in place of IGBT as a switch but the output is zero volt.so how this happen can anyone tell me pls
A FET can be turned on and off by the gate voltage. A triac or SCR will turn on when current flows through the gate, but will not turn off when the gate current is removed as long as there is still anode current flowing. The anode current must be reduced to zero to shut off these devices. Thus triacs and SCRs work well in AC circuits where the current periodically goes through zero, but don't work in DC circuits unless some other method is employed to reduce their current to zero.why i cannot use the triac in place of IGBT as a switch in flyback converter.why it will burn .Whats the logic behind that.can u pls explain me brother
how we can use the triac and SCR as a switch in flyback converter
