need help with servo circuit
gellwood
What I need to do is measure the load on a analog servo and light an LED if the servo should draw excessive power due to a bind in the control linkage from the servo to a control surface.
Have a look at this post https://www.electro-tech-online.com/threads/question-stereo-tape-head-preamp.16604/ subject Pls help.
The INA169 provides an output voltage that is proportional to the current through the resistor. If the TLC2272 was configured as a Schmitt Trigger, it would give you an output when the current increased above the threshold.
However, you may need a low pass filter or delay to prevent triggering to current spikes. Also, motors usually draw a high current on starting.
Len
