need help with resistor math ;)
strokedmaro
I have 2 solenoids that are read by a computer. Each solenoid has about 25 ohms and has 12 vdc applied all the time...solenoids are controlled by a ground supplied from a computer. I currently use two 25ohm, 5 watt resistors to "fool" the computer into seeing the solenoids and want to try and use just 1. How would I figure that out. Basically two grounded computer pins connected to a single resistor, connected to 12vdc. Any help appreciated. THANKS!
So, if I understand your correctly, you want some sort of relay simulator, that is something that has the same I draw as your relays. Using ohms law I=E/R 12v/25:ohm: = .48 amp Using ohms law again P = IxE 12 x .48 = 5.76W
But now you want to simulate two relay (In parallel I presume) so two 25 ohm resistors in parallel equals halve the value of two equal resistors, in this case 25:ohm: = 12.5:ohm: So I think you want a 12.5:ohm: resistor rated @ 12W or better.
