need help with power supply parts very info...
rodniepr
i have a receiver 301 013 from dish network that works ok for 1 hour after that the receiver go off i desconect from the electric outlet and reconect and the reciver dont turn on
if i wait like 15 minuts the receiver and connect to the electricity again it turn on and works 100% but after like 1 hour again it turn off
a friend of mine told me that the power supply its the first think to verify because the tsop and eeprom are ok just when the receiver are hot it turn off
wwhat you think ?waht can i verify on the power supply?
one more thing its that i verify all the capacitors diode. regulator switch and only one has 1 of power
some guys at dish forum told me to verify the regulator switch hs5001..or the bridge diode cr5008
or the main filter cap. c9001
check parts here to see the work info for that part
if the problem are that the receiver turn hot and when its hot it turn off what i need to change?
i have 1 receiver that all the power supply parts are ok
what you said??**broken link removed**
