Need help with 18f2520 variable issue
mastero
Hello all,
I have run into a very funny problem...
i am using USART for communication with SIM908
everything works fine then suddenly the variables automatically change from true to false.
There is no voltage and amp issue....
any idea what causes this error ??
regards
mastero
I cant post the code ..... i will get in trouble
also the code is too long....
this happens in random ..... can a stack over or under do this ??
found the issue and solved it ...
How many times can one use a variable example
Dim check as bit
Is there a limit for the use of variable check ?
regards
mastero
