Need help / verification error and invalid target id warning PIC16F877
makris
Hi, I am a university student and I am trying to go over some tutorials that were given to me by my supervisor and I am encountering some strange errors. It should be noted that this is my first time I am attempting PIC programming so all I know for sure is that I am following the tutorial step by step so it is pretty clear to me that something is happening that was not suppose to happen.
I am using MPLAB IDE v.7.4 and MPLAB ICD2 as the controller. My PIC16F877 is connected onto a PIC board which has a 20MHZ crystal a MAX232 and is connected onto the controller using an RJ11 connector. The PIC is powered by an external adaptor of 5V/1A and there are also 8 LEDs onto all B pins.
The code I am using is a basic LED counting test:
//LED counting test.c
#include<16F877.H>
#pragma fuses HS,NOWDT,NOPROTECT,NOLVP
#pragma use delay(clock=20000000)
void main()
int value;
set_tris_b(0x00);
for(value=0; value<=60; value++)
OUTPUT_B(value);
delay_ms(1000000);
MPLAB gives me a warning and an error
Warning:
ICDWarn0020: Invalid target device id (expected=0x4D, read=0x1FF) Error:
ICD0161: Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x3000, Val Read = 0x3FFF)
I’ve been looking around through the internet for similar topics but I can’t seem to figure out what’s wrong. What got me really confused is the fact that I bought a new PIC just to try and see if it got fried, and the first time I tried to program it, it worked. But the weird thing is after being programmed once it started the same problems as the previous PIC.
I also tried to set the memory locations as manual like some forums suggested but nothing changed.
The Self test numbers are:
Target Vdd: 5.04
Target Vpp:12.46
MPLAB ICD 2 Vpp:12.54
And additional info:
Oscillator HS
Watchdog timer OFF
Power Up timer OFF
Brown Out detect ON
Low Voltage Program DISABLED
Flash Program write ENABLED
Data EE read protect OFF
Code Protect OFF
Thanking you in advance,
Kyriacos Makris
Warning:
This means that the chip cannot be seen.. The ICD knows there is something there but not a pic16f877. Check that the connections for programming are correct otherwise the pic may be duff.
If its a new chip then it must be connections... Are you sure the correct device has been set?
Yes it is correct,
the weird thing is, if the case is that it cannot be seen then it shouldn't have worked the 1st time I installed the new one,right?
Yes I am monitoring it as it goes through the proccess of erasing and programming again.
How can I check the current that goes through those pins?How much should it be?
And what kind of schematic are we talking about?
Thanks again for helping me out!!
It seems that it does not actually erase what is on the PIC although it says it was succesfull.
MPLAB ICD 2 Ready
Erasing Target Device......
Erase Succeeded
MPLAB ICD 2 Ready
Blank Checking......
Program MemoryICD0161: Verify failed (MemType = Program, Address = 0x1000, Expected Val = 0x3FFF, Val Read = 0x0)...
Device not blank
MPLAB ICD 2 Ready
Programming Target......
Validating configuration fields...
Erasing Part...
Programming Program Memory (0x0 - 0x38)
Verifying......
Program Memory
ICD0275: Programming failed.
MPLAB ICD 2 Ready
here you go,is that what your looking for?
well that might be good news, at least i know am not doing anything wrong,all I need is to get another PIC board
its something custom made from what i can tell,here is a schematic for it...
If the PIC is in a socket (1) check the IC orientation, (2) confirm no pins are bent under, (3) confirm IC is seated fully in socket.
so is it safe for me to just rotate the PIC around just to check if that works??because i don't really know where each RJ11 wire should connect to the PIC this is the only way I could check the orientation of the list...
i tried programming it without the LEDs connected all together and it makes no difference. To be honest i noticed that initially when plugged in all the LEDs are lit and once a connection has been established the 2 1st LEDs turn off and play around randomly every time a procedure is in place.
No. Pin 1 of the IC is identified by a small circular dent in the top of the IC. The pins are numbered counter-clockwise. The circuit board or socket should have some marking to indicate where pin 1 should be placed.
We can't see any wires from here!
:confused:
