need help ..... UPS circuit diagram
It's a pair of diodes combining a battery output with a power supply output. A seemingly trivial schematic, which I do not believe requires a drawing. Maybe, I missed something in your original post, and there was something else you had in mind. Can you elaborate?
i've seen a medium cabinet that contain an UPS , its used for a HAEMODIALYSIS UNIT so it doesn't looks like a normal UPS ....... thats why i wanna know what its looks like , i mean the circuit .....
It makes a difference if the power supplied is AC or DC. The previous answer I gave was appropriate for a UPS with a DC output. If the UPS in which you are interested is an AC unit, then the batteries are used to power an inverter which converts DC back to AC. The AC from the mains and the AC from the inverter are switched so that power is drawn from the mains if they are there and from the inverter when they are not. To track down what you are looking for I suggest you start by investigating the DC to AC inverter circuit.
As it's for medical equpment, don't even attempt buiding one or even buying one unless it's been approved to use with the device in question.
Buy one from the supplier of the haemodialysis unit and check that it's compatible with the make and model.
If you bodge a UPS together and it damages the equipment you might be held personally responsible for the injury of the person using the machine!:eek:
