slapdash41
hi there,
Can someone here do me a favor to translate this PICBasic code which is from Turkishto English. Only translate the comment and LCD output. Already used automated translator software but can't understand it. Need this urgent .. Here is the source:
16F628 YILDIZ-ÜÇGEN KUMANDA (Yıldız Üçgen Yol Verme)
PICBasic Code
PICBasic Code
'* Name : YILDI ÜÇGEN RÖLE.BAS *
'* Author : X0914667@yahoo.com *
'* Notice : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 08.07.2006 *
'* Version : 1.0 *
'* Notes : *
Define LCD_DREG PORTB 'LCD DATA TANIM AYARLARI
Define LCD_DBIT 4 'LCD TANIM AYARLARI
Define LCD_RSREG PORTB 'LCD RS TANIM AYARLARI
Define LCD_RSBIT 2 'LCD TANIM AYARLARI
Define LCD_EREG PORTB 'LCD RE TANIM AYARLARI
Define LCD_EBIT 3 'LCD TANIM AYARLARI
DEFINE LCD_LINES 2 'LCD SATIR SAYISI
'*********************DEÐÝÞKEN TANIMLARI*************************
SAYAC VAR BYTE 'ZAMAN SAYACI 1 SN.'LÝK
SANIYE VAR BYTE 'SANÝYE SAYACI
KUMANDA VAR BIT
UCGENEGEC1 VAR BIT
B1 VAR BYTE
B0 VAR BYTE
B2 VAR BYTE
B3 VAR BYTE
B4 VAR BYTE
B5 VAR BYTE
'*******************ZAMAN SAYACI ÝNTERRUPT AYARLARI**************
ON INTERRUPT GoTo KESME 'kesme oluþursa KESME adlý etikete git.
OPTION_REG=%10000101 'Pull up dirençleri ÝPTAL- Bölme oraný 1/64.
INTCON=%10100000 'Kesmeler aktif ve TMR0 kesmesi aktif
TMR0=0
CMCON=7
clear 'BÜTÜN DEÐÝÞKENLERÝ SIFIRLA
LCDOUT $FE,1 'LCD'YÝ TEMÝZLE
PAUSE 500 'LCD ÝÇÝN BEKLEME ZAMANI
'TRISA=%
'TRISB=0 'PORTB ÇIKIÞ
'*****************AÇILIÞ ÝÇÝN KAYAN YAZI**************************
LOOP:
LCDOut $fe,2
For B2= 0 TO 15
LookUp B0, [" OTUGEN OTOMASYON #"], B1
IF B1 = "#" Then GoTo reset
LCDOut B1
B0 = B0 + 1
Next B2
pause 125 'KARAKTER BEKLEME ZAMANI
B0 = B0 - 15
GoTo loop
RESET:
LCDOUT $FE,1
onprogram:
LCDOUT $FE,$80
LCDOUT " YILDIZ UCGEN "
LCDOUT $FE,$C0
LCDOUT " KUMANDA ROLESI "
PAUSE 500
LCDOUT $FE,1
ANAPROGRAM:
IF PORTA.7=1 THEN
GOTO ARIZA
ELSE
GOTO NORMAL
ENDIF
ARIZA:
LCDOUT $FE,$80,"MOTORUN TERMIK"
LCDOUT $FE,$C0,"ROLESI ATTI "
LOW PORTB.0:LOW PORTA.3:LOW PORTB.1
KUMANDA=0:SAYAC=0:SANIYE=0
GOTO ANAPROGRAM
NORMAL:
LCDOUT $FE,$80,"MOTOR:"
IF PORTA.3=0 THEN
GOTO mesajstop
else
goto start
endif
mesajstop:
lcdout $fe,$86,"STOP "
LCDOUT $FE,$C0," "
GOTO KONTROL
START:
lcdout $fe,$86,"START "
GOTO KONTROL
KONTROL:
IF (PORTA.1=1) OR (PORTA.7=1) THEN GOTO MOTORDUR
IF (PORTA.1=0)AND(PORTA.7=0)AND(PORTA.0=1)OR(KUMANDA=1) THEN
GOTO MOTORYILDIZ
ELSE
GOTO MOTORDUR
ENDIF
MOTORYILDIZ:
KUMANDA=1
IF SANIYE=15 THEN
UCGENEGEC1=1
ENDIF
IF UCGENEGEC1=1 THEN GOTO UCGEN
LOW PORTB.0:HIGH PORTA.3:HIGH PORTB.1
LCDOUT $FE,$C0,"CALISMA YILDIZ"
GOTO PROGRAMDEVAM
UCGEN:
HIGH PORTB.0:HIGH PORTA.3:LOW PORTB.1
LCDOUT $FE,$C0,"CALISMA UCGEN "
GOTO ANAPROGRAM
MOTORDUR:
PROGRAMDEVAM:
GOTO ANAPROGRAM
'********************ZAMAN RÖLESÝ PARAMETRELERÝ**************************
DISABLE
KESME:
IF KUMANDA=1 THEN
GOTO SAY
ELSE
GOTO DEVAM
ENDIF
SAY:
SAYAC=SAYAC+1 'kesme sayacý 1 sn= 61(sayac) x 256 (Tmr0) x 64 (bölme)
IF SAYAC=61 then '61 adet kesme olunca 1 sn. süre geçiyor.(999424 us)
SAYAC=0 'sayaç sýfýrlanýyor
SANIYE=SANIYE+1
' GOSUB ZAMAN_OKU
' if Y<5 then HIGH porta.3
ENDIF
DEVAM:
INTCON.2=0 'TMR0 Kesme bayraðý sýfýrlanýyor
RESUME
ENABLE
