Need help to interface a ps/2 mouse with 12f629
iamyanh
I have problems in interfacing a ps/2 mouse with 12f629. But it seems that the 12f629 have no data transfer to the mouse or no data recept from the mouse! Here is my c program. Can anyone find out why? Thank you!
#include <pic12f6x.h>
#include "delay.h"
#include "delay.c"
/* difine the data and clock line*/
static volatile bit clk @ (unsigned)&GPIO*8+1; /* bit1 in portA */
static volatile bit dataline @ (unsigned)&GPIO*8+2; /* bit2 in portA */
static volatile bit clk_tris @ (unsigned)&TRISIO*8+1; /* bit1 in trisA */
static volatile bit dataline_tris @ (unsigned)&TRISIO*8+2; /* bit2 in trisA */
/*Define the command to the mouse*/
#define MS_RESET 0xff
#define MS_DATA_REPORTING_ENABLED 0xf4
#define MS_SUCCESS 0xaa
#define MS_DEVICE_ID 0x00
#define MS_ACKNOWLEDGEMENT 0xfa
/* Prototypes */
void wait(unsigned char t);
void sendData(unsigned char data);
unsigned char recvData(void);
void sendData(unsigned char data){
char i;
unsigned char parity = 1;
clk_tris = 0;
dataline_tris = 0; //Both the clock and the data line set to output
clk = 0; //Drive the clock low
DelayUs(100); //For at least 100MS
dataline = 0; //Drive the data low <-------------start bit
DelayUs(10); //For 10 MS.
clk_tris = 1; // Release the clock.
//<-------------------------Send 8 data bits
for(i=0; i < 8; i--) { //8 bit,so perform 8 cycles.
while(clk) DelayUs(10); //Wait for clock low to jump to next
dataline = data & 0x1; // Send the LSB.
parity += data & 0x1; // Calculate parity.
data = data >> 1; // Shift data.
while(!clk) DelayUs(10); // Wait for clock high to jump out.
dataline = parity & 0x1; // <------------------------Send parity
dataline = 1; //<-------------------------Send stop bit.
dataline_tris = 1; //Release the Dataline.
while(dataline); // Wait for acknowledgement bit(Low).
while(clk); // Wait for clock goes low.
while(!clk || !dataline); // Wait for mouse releases clk and dataline to both high.
unsigned char recvData(void) {
unsigned char data = 0x0;
unsigned char parity;
char i;
clk_tris = 1;
dataline_tris = 1; //Both dataline and clock is set to high.
while(!clk) DelayUs(10); // Recieve the start bit.<------Start bit.
for(i=0; i < 8; i--) { //<------------8 cycles to receive the 8 bit
while(clk) DelayUs(10); // Wait for clock line to go low.
data = data >> 1; // Shift buffer.
data += dataline * 0x80; // Read next bit into buffer.
parity += data & 0x1; // Update parity.
while(!clk) DelayUs(10); // Wait for clock to go high.
while(!clk) DelayUs(10); //Parity bit
while(!clk) DelayUs(10); //Stop bit
return data;
void main(void) {
//INTCON=0X00; //
//CMIE=0; //
//CMCON=0x13; //
//CMIF=0; //
//WPU5=1; //
clk_tris=0;
dataline_tris=0;
sendData(MS_RESET); // Reset mouse.
while(recvData() != MS_SUCCESS); // Wait for self-test success.
while(recvData() != MS_DEVICE_ID); // Wait for mouse device id to be
sendData(MS_DATA_REPORTING_ENABLED); // Enable data reporting.
while(recvData() != MS_ACKNOWLEDGEMENT); // Wait for acknowledgement
//*After that mouse is in data reporting mode
while(1) {
sendData(0xEB); // Report the status
recvData();
recvData();
recvData(); //Receive the 3 Byte data from the mouse in each cycle.
DelayMs(20); //Delay for 20 miliseconds
have you heard of the "EZmouse"?
its really simple to interface to, and it might solve your problem...
take a peek.... it couldnt hurt....
Thanks to VBguru,but I really dont want to attach this Ezmouse in my PCB,I want to program it in my own chip.
have you checked the code samples? they may give you some insigh to your problem....
also
https://www.awce.com/pak11.htm
right side bottom of the little window....
might have something usefull...
Sorry i counldnt be more help
