need help quick!!!! basic stamp......
jhill44
here is a copy of the program i am running........ i have constructed a bot that i am hoping to run autonomously. this is basically an automated refrigerator with obstacle avoidance. with the basic program that i am running right now a universal remote initiates the movement of the bot and it then runs through the obs. avoidance. as it runs through the obs. avoidance i would like to beable to stop the bot by pressing another button, but with the way i have it written it wont exit out of the loop command....... i have tried many different things to try and execute this simple stop command but nothing seems to work.. any suggestions
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "program running"
'------------[variables]-----------------------------------------------
irdetectleft VAR BIT
irdetectright VAR BIT
irdetectcenter VAR BIT
BUTTON_CODE VAR BYTE 'Infrated Button Code
DEVICE_CODE VAR BYTE 'Infrared Device Code
'------------[main routine]--------------------------------------------
'* MAIN PROGRAM *
MAIN:
GOSUB COMMAND_030 'Send the Remote control Command to Infrated Control Freak
GOTO MAIN
COMMAND_030:
SEROUT 14, 16468, [30]
poop:
SERIN 15, 16468,1000,main, [device_code, button_code]
DEBUG "button code =", DEC Button_Code," Device Code =",DEC Device_code," ", CR
DEBUG " ",CR
DEBUG "____________________________",CR
DEBUG HOME
IF Button_code = 21 AND Device_code = 1 THEN obstacle_avoidance
IF BUTTON_code = 101 AND device_code = 1 THEN STOP_bot
GOTO poop
'----------[subroutines]----------------------------------------------
obstacle_avoidance:
DO
FREQOUT 8, 1, 38500
irdetectleft = IN9
FREQOUT 2,1, 38500
irdetectright = IN0
FREQOUT 3,1, 38500
irdetectcenter = IN4
IF (irdetectcenter = 0) THEN
GOSUB back_up
ELSEIF (irdetectleft = 0) THEN
GOSUB turn_right
ELSEIF (irdetectright = 0) THEN
GOSUB turn_left
ELSE
GOSUB forward_pulse
ENDIF
LOOP
forward_pulse:
PAUSE 100
SEROUT 16, 8276, ["!A1E", CR]
SEROUT 16, 8276, ["!b1E", CR]
RETURN
turn_left:
PAUSE 20
SEROUT 16, 8276, ["!A14", CR]
SEROUT 16, 8276, ["!b14", CR]
RETURN
turn_right:
PAUSE 20
RETURN
back_up:
PAUSE 20
SEROUT 16, 8276, ["!a1E", CR]
SEROUT 16, 8276, ["!B1E", CR]
RETURN
STOP_bot:
PAUSE 20
SEROUT 16, 8276, ["!A00", CR]
SEROUT 16, 8276, ["!B00", CR]
