Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
Note that many autos have a Vehicle Speed Sensor already built in others have a Crankshaft Speed Sensor built in. The detailed shop manuals often describe the sensors as well as what one would expect to see in terms of output from the sensors.
Note also that the Antilock Braking Systems have some means of measuring individual wheel rotations. You might "steal" a signal from there - realizing it's only one of 4 wheels.
One thing we use on drag cars for the data logger is a rare-earth magnet attached to the tailshaft, set up a Hall effect sensor to read the magnet, and work out the road speed from the gear ratios (differential) and the tyre diameter.
2 things to bear in mind - The shaft will move up and down if the car has suspension fitted, and there may be tyre spin.
Second option is to attach the magnet to the front wheel - remembering that this may become airborne at times! :twisted:
You could also try taking input from an accelerometer, such as this one from Crossbow: **broken link removed**. I used a three axis once to build a system to gather very detailed information on my decents when I would go downhill biking, and was able to find out my forward velocity at any given point on my trip with just a little math. For a car through, some very simple math with a 1 axis would allow you to find speed.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
