wejos
i'm using 16f84 and ran into these errors. first time to see one like this. i have no idea what's going on maybe i messed up some settings and changed by accident the default path for the "inc" files, i have no clue also where to change this setting. and it says goto, mov, call, and etc. cannot be recognized, i have this assumption that these commands or instruction set are built in. help me please lol i am lost.
the fuses that i used:
LIST p=16F84 ;tell assembler what chip we are using
include "P16F84.inc" ;include the defaults for the chip
ERRORLEVEL 0, -302 ;suppress bank selection messages
__CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC
;sets the configuration settings (oscillator type etc.) or RC_OSC if thats what your using
Release build of project `C:\asmproj2.disposable_mcp' started.
Language tool versions: MPASMWIN.exe v5.30.01, mplink.exe v4.30.01
Tue Jan 01 07:23:52 2002
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F84 "asmproj2.asm" /l"asmproj2.lst" /e"asmproj2.err"
Warning[205] C:\ASMPROJ2.ASM 2 : Found directive in column 1. (LIST)
Warning[205] C:\ASMPROJ2.ASM 8 : Found directive in column 1. (org)
Warning[203] C:\ASMPROJ2.ASM 9 : Found opcode in column 1. (goto)
Warning[205] C:\ASMPROJ2.ASM 30 : Found directive in column 1. (org)
Warning[203] C:\ASMPROJ2.ASM 32 : Found opcode in column 1. (MOVLW)
Warning[203] C:\ASMPROJ2.ASM 33 : Found opcode in column 1. (call)
Warning[203] C:\ASMPROJ2.ASM 34 : Found opcode in column 1. (bcf)
Warning[203] C:\ASMPROJ2.ASM 35 : Found opcode in column 1. (retfie)
Error[113] C:\ASMPROJ2.ASM 222 : Symbol not previously defined (res)
Error[113] C:\ASMPROJ2.ASM 233 : Symbol not previously defined (res)
Warning[205] C:\ASMPROJ2.ASM 244 : Found directive in column 1. (res)
Error[113] C:\ASMPROJ2.ASM 244 : Symbol not previously defined (bsf)
Error[112] C:\ASMPROJ2.ASM 244 : Missing operator
Error[108] C:\ASMPROJ2.ASM 244 : Illegal character (,)
Warning[231] C:\ASMPROJ2.ASM 244 : No memory has been reserved by this instruction
Warning[205] C:\ASMPROJ2.ASM 261 : Found directive in column 1. (end)
Halting build on first failure as requested.
Clean: Done.
