Need a place to start...
Jester009
I need to come up with a circuit to generate alternating currents. (Range 0-5A sinusoidal) It needs to be controlled through a user interface in the computer. I'm clueless guys. Plz help...
Give me a place where can start. I should admit that I'm a NOOB :(
Anybody have any idea??
I have got three suggestions so far...
1). Using a triac with a PIC to control its firing angle...
2). Generate PWM and drive a half bridge with IGBT's...
3). Use an audio amplifier controlled by audio signal source...
I don't have an in-depth knowledge about any of these designs. Can anybody please comment on these... I'm kinda lost :(
Can you give us an idea of what frequency and voltage ranges you want in addition to the 0-5A capability?
This will give you a fixed output frequency and not a very nice sinewave at all.
This will do what you want, but is somewhat complicated for a noob.
This is will also work over a limited frequency range determined by the audio amp's frequency response.
You could use something like this with the audio amp:
Hi kchriste,
Thanks a lot for the reply. This is going to be used to test relays, i.e. apply a specified current and measure the tripping time. I don't have a clear idea about the voltage :( I have to generate a 50Hz sine wave of specified current ranging (0 - 5A)
I decided to take the amplifier option. So I guess the basic block diagram should be like this...
I still don't have an in-depth knowledge about the design. :(
I searched a bit and came up with a signal source. Hope I'll be able to use this...
http://wiredworld.tripod.com/tronics/signal_source.html
Please add comments... Will it be easy to follow the design with IGBT??
If its 50Hz and sinusoidal, why not use a Variac Transformer to drive a 1:1 isolation transformer [ thats if the isolation is required] ?
The voltage isnt specified, so taking the worst case as mains ie; 250Vac then
250 * 5 = 1.25KVA rating for both transformers.
You can get motorised Variacs that the PIC/driver can control.
Yes I agree, but It's better to have the isolation transformer as at low voltages the current will be 'lost' magnetising the isolation transformer,
