Need a certain PIC...
2camjohn
I need a pic with a precise ADC like the PIC12f675 but with at least 8 IO pins like the 16f628a.
I would like an internal OSC, a timer and interrupt capability too.
I dont want something as large as the PIC16f877, 18 pins would be as big as I could go.
I know I should read through all the datasheets but I figured if someone is using a chip that fits this criteria then I would have a place to start looking.
John
Try the 16F819, it's got 10 bit A2D in an 18 pin package, as well as everything else you wanted. The 16F88 is another choice.
16F676 is another choice. 14 pin package, 8 ch 10 bit A/D, int. oscillator.
The 16F676 seems like the way to go out of those choices.
It is supported by my programming software but not by WinPicProg (1.91)
Nigel is ther a way of extending the range of PICs that WinPicProg supports?
Also will my programmer (PIC16PRO40) support the chip even though it only has 8 18 and 40 pin sockets??
John
There's no external way of doing it in WinPicProg, doing it that way isn't very practical because of the different programming algorithyms used for various different PIC's.
Yes, I've programmed 14 pin PIC's in the P16PRO40.
The later versions of WinPicProg already support the 16F676, you can download the latest beta (1.95C) from a link in the Announcements section of the Forums. There's a list of supported devices at .
