n00b with a tail light query
First off - HI :D
I've done a search on this but couldn't find anything that answered my question specifically.
I'm trying to construct some custom rear lights (like alot of other people I see on here), and I'm hitting problems.
This is what I want to happen
normal lights on....
brakes on....
The problem I'm having is that when I simulate normal lights on, all of the lights light up dim, not just the ones I want.
This is how they are currently wired up... (please excuse the shocking skill )
Thanks in advance for any advice offered... or comments on my skillz :lol:
Ant
If you close the first switch, you can easily see that one of the paths for current flow could be as follow.
switch -> 1kohm -> 100ohm -> 100ohm -> 5leds -> gnd
Why not reorganise your switches. There's a master on-off switch, and another switch which is default-on to light up the centre cross?
As per Nigel's suggestion.
Modify the last circuit so that all resistances are more equal. Replace the 1K with a diode, andshort the 100 ohm before the diode already present. put a resistor between the point where two diodes meet and the string of lights. Now make all resistances the same value. Don't go lower than 100 ohms.
Is this for a motorcycle or a car?
I replaced my cars tail light bulbs with store bought LED fittings and now my blinkers go super fast. I hope to someday get the entire taillight assembly from a junk car ('97 cougar), open them up and make a huge board of LED's over the entire red reflector part. Hmm, if I moved the license plate, I could put a huge scrolling message board accross the back of my car. Tell all those tailgaters what I think of them, lol.
~Mike
Why not just have the middle lights always on, connected to the 12v all the time, and the outer lights connected to the brake?
Thought you have spotted a mistake and doing it your way can save one resistor? :twisted:
The different resistor values are there for a good reason. If you don't get it, go out tonight and watch the brake light when the driver brakes.
Nigel Goodwin said:
You need two diodes to make an OR gate to feed the centre LED's, or even one would do - on the brake light side.
Thanks for all the suggestions guys,
Nigel and eblc1388, from what I have read on various pages, your suggestion will be the first one I try as I believe this will give me the results I'm after.
Its for a car by the way.
Thanks again,
Ant
eblc1388 said:
mstechca said:
Modify the last circuit so that all resistances are more equal. Replace the 1K with a diode, andshort the 100 <a href="#">ohm</a> before the diode already present. put a resistor between the point where two diodes meet and the string of lights. Now make all resistances the same value. Don't go lower than 100 ohms.
yes, but he's got 1/4 the LED's for the tail light so that its duller than the brake lights, he doesn't need to make the LED's dimmer aswell...
