Richardcavell
Hi all,
I am a novice self-taught electronics enthusiast. I have been considering how to send x number of digital data lines into a microcontroller that has y data lines, where x > y. The way I've chosen to do this is to use an output line to turn on one of two transistors that are mutually exclusive. That will connect either M or N to the relevant data line. This idea can be propagated across all the data lines, thereby effectively doubling the number of possible inputs at the expense of one output data line.
1. Is this the basic method by which multiplexing is done?
2. There will be a propagation delay through the NOT gate, but not on the M side of the circuit. Should I be worried about this?
3. There will be a current from base to emitter through the transistor that is active, even if the current-emitter junction has no current. This will mean that the data line will always read as true unless I account for it. How do I account for it?
Thanks in advance,
Richard
Thanks in advance,
Richard
