Multiplexing 7-Digits?
Hey there!
I got the routines and the small 0-99 counter for that microcon, but I can't seem to get 2 displays working at the same time.
I tried putting the "displaying two displays" at the interrupt section, and I got stuck. Here's the code:
#include <htc.h>
__CONFIG(INTIO & WDTDIS & PWRTEN & MCLRDIS & UNPROTECT
& BORDIS & LVPDIS);
                //0b0gfedcba
char numbers[] = {0b00111111, // 0
    0b00000110, // 1
    0b01011011, // 2
    0b01001111, // 3
    0b01100110, // 4
    0b01101101, // 5
    0b01111101, // 6
    0b00000111, // 7
    0b01111111, // 8
    0b01101111, // 9
int i, j, k;
int counter;
int ones = 0;
int tens = 0;
void interrupt tmrlint(void)
    if(TMR1IF)
        TMR1IF = 0; //got stuck over there!
void main()
    TRISA = 0x00;
    TRISB = 0x00;
    PORTA = 0b0000010;
    PORTB = 0x00;
    PEIE = 1;
    GIE = 1;
    TMR1IE = 1;
    T1CON = 0b00110101;
    while(1)
        ones++;
        if (ones > 9)
            tens++;
            ones = 0;
what could i have been missing? :confused:
I dont see anywhere in your code the actual multiplexing, perhaps you do not understand. You must switch between the two faster than the eye can see (24Hz)..about 50Hz will show no blinking. You display one digit and then the other back and forth. If you want this to be visible counting your going to need to use a delay. Why are you using a timer 1 interrupt? Lastly GIE (global interrupt enable) Should be the last bit enabled.
    PEIE = 1;
    GIE = 1;
    TMR1IE = 1;
    T1CON = 0b00110101;
should be
    PEIE = 1;
    TMR1IE = 1;
    T1CON = 0b00110101
    GIE = 1;
Please explain what you are trying to do more.
Mike
    PEIE = 1;
    GIE = 1;
    TMR1IE = 1;
    T1CON = 0b00110101;
should be
    PEIE = 1;
    TMR1IE = 1;
    T1CON = 0b00110101
    GIE = 1;
Mike
Oh sorry for the confusion - I'm attempting to multiplex, and I formed the flow-chart. I know it's these 2 displays which go back and forth very quickly, and i need to implement it into the interrupt, but I kinda got stuck here. I might crack some more head of myself first, and post the code later. :rolleyes:
Ah i see
well youll want to do something like
   Goto ISR      ; Interrupt service routine
ISR
     TMR1IF = 0
     PORTB pin x = PORTB pin x ^1   ;<--- not sure how to write in C
     PORTB pin y = PORTB pin y ^1   ;<--- just invert the pins and they
                                                 ;      will swap
     RETFIE   <--- asm instruction not sure about C
You will still need to work out a delay though, this could be a problem since you are getting an interrupt VERY often.
BTW which uC???
Hope this helps,
Mike
Ah i see
ISR
     TMR1IF = 0
                                                 ;      will swap
BTW which uC???
Hope this helps,
Mike
My microcontroller is PIC 16F682A, as recommended by Nigel GoodWin. :D
How about using a task counter? Like task_count++, then wait for it to reach the max intended task count and then exit the interrupt? :)
I'll asume you meant 628a*
I don't see why you would want to complicate things, why use the interrupt at all?
And actually I believe that while your trying to do the "task count" the interrupt would be triggered all over again...huge mess.
Mike
