AUSTStudent
In my project, I am using sensors connected to PIC16F877. I have to get the readings from the sensors and display the value on the Computer (through parallel port). For example, I am using LM35 to display the temperature value on the PC (using Visual Basic). When I want to display, more than 1 sensor reading, it doesnot work. I want to use three ports for A/D conversion to display three different readings.
For synchronization between PC and PIC16F877, I am using control pins of parallel port. The temperature reading is displayed correctly on PC from the 3 ports. Since, sensors are not available now, I am using voltage less than 1.2V from the bread board to check, if synchronization is achieved or not. Along with the voltage from LM35, when I add any other voltage, I get the same reading of the temperature, i.e., the two ports are reading the same value, how is that possible, although I am putting 2 different voltage on AN0 and AN1???
I am programming using picbasic pro and the code is shown below.
define ADC_BITS 10
define ADC_CLOCK 3
define ADC_SAMPLEUS 50
x var word 'ADC is made 10 bits for proper resolution of LM35
y var byte
a var word
b var byte
c var word
d var byte
TRISA=255
TRISB=0
TRISD = 255
ADCON1=%10010010
pause 500
loop:
if (portd.0 = 1) AND (portd.1 = 0) Then
ADCIN 0,x
y = x 'the last two bits will be discarded, but the reading for temperature is correct.
PortB = y
output PortB
pause 500
endif
if (portd.0 = 0) AND (portd.1 = 1) Then
ADCIN 1,a
b = a
PortB = b
output PortB
pause 500
endif
if (portd.0 = 1) AND (portd.1 = 1) Then
ADCIN 2,c
d = c
PortB = d
output PortB
pause 500
endif
goto loop
By proper programming in Visual basic, the control pins are changing, i.e., portd.0 and portd.1 is changing as 10, 01, 11. But, why is that the microcontroller is not reading multiple inputs separately??
Plz help
Thanx a lot...
define ADC_BITS 10
define ADC_CLOCK 3
y var byte
a var word
b var byte
c var word
d var byte
TRISA=255
TRISB=0
TRISD = 255
ADCON1=%10010010
pause 500
loop:
ADCIN 0,x
PortB = y
output PortB
pause 500
endif
ADCIN 1,a
b = a
PortB = b
output PortB
pause 500
endif
ADCIN 2,c
d = c
PortB = d
output PortB
pause 500
endif
goto loop
Plz help
Thanx a lot...
