motor speed ( following all my motors question)
Is that the entire sequence? Is there more?
Oh sorry, when I red cycle I was thinking of the PWM...
I used that for an example. What I wanted to illustrated was the irregularity of the cycle not just 5sec run, 5 sec stop, 5 run...
But just because I want it simple, I can accept the "just 5sec runs, 5 sec stop, 5 runs..."
short out the PWM timing cap with the output of the sequence generator through a diode.
I'm sorry, I speak french. I don't understand what you mean especially "short out the pwm timing cap"
Use the timing generator to pull the PWM capacitor to ground.
I know I will look stupid and I'll get you on the nerve but which timing?
I know so little in electronic...
When you talk about the timing cap do you talk about the pin 5 of the 555 in my circuit here PWM tutorial
If I add a timer, I will pull out the cap and connect the output of the timer to the pin 5?
If you are just looking to turn it on and off you tie a diode from pin 3 of one to pin 2 of the other with the cathode to pin 3. When the output of the first one is low, it holds pin 2 low turning off the motor.
