monotone melody using buzzer
rrb011270
Mabuhay!
I have a PIC system and I am planning to integrate a monotone melody using a buzzer...
Can anyone help me? a code snippet will do....
Thnx
Mabuhay rin sa'yo
If your using a buzzer (like the sonalert ones from Alexan) all you do is apply a voltage across the leads. It already has a built in oscillator/drive circuit.
But if you all you have is a ceramic disk or a speaker and would want to use the PIC to pulsout a ceratin frequency. Here's some codes:
The easiest is to use PICBASIC. (Download it from sonsivri.com.)
All you do is use the FREQOUT command:
__________________________________
FREQOUT portb.1, 500, 528 ' Output to portb pin1, for 500 msec,
' 528hz, which is the note C.
Before, I actually did it in assembly, which is about ten times
more 'econimical' that the PICBASIC equivalent.
; Variable
d3 equ 0X0F ; Variable used to count the number of
; cycles in the duration the sound is
; played.
; d3 = 528 * duration of sound (sec)
; Play sound
MOVLW 0X108 ; Put the value 108h (decimal, 264)
MOVWF d3 ; to d3. A 528hz freq completes 264
; cycles in 500 msec.
Call C1
; C2 Subroutine
C2
BSF PORTB,1 ; High portb pin1.
Call C2_0 ; Call delay subroutine
BCF PORTB,1 ; Low portb pin1.
DECFSZ d3, f ; Decrement d3
goto C2 ; Goto to C2. If d3 is zero
RETURN ; end subroutin
; Delay routine for the on-off sequence
C2_0
MOVLW 0xBD
MOVWF d1
MOVLW 0x01
MOVWF d2
C2_1
DECFSZ d1, f
goto $+2
DECFSZ d2, f
goto C2_1
goto $+1
goto $+1
RETURN
______________________________________
Hope this helps.
Do you mean it is easier in assembly or picBasic?
I've wanted to learn assembly but was lead to believe it wasn't easier to program in than basic.
I meant that a program in assembly, while more complicated to do,
typically uses up less program memory--economical.
But programming in PICBASIC is far easier. In fact now I program exclusively in PICBASIC and have cut my programming time a great deal.
I find that trading off some memory 'real estate' is worth the time savings.
/John
(I ckecked: In the examples above, the code in assembly saves 31 words.)
Anyone have done using ANSI C or any C-Language?
/John
