Hello Sign,
Post 53 gives your schematic, but it's for a 12v system. Perhaps the Velleman sheet I gave you didn't have the 6v option. Attached new Velleman file does have the 6v option. Would it be a simple substitution of the listed resistors?
Ah, I see your thinking. No, the circuit of post #53 is for a 6V system. 12V is only used to drive the gate of the NMOSFET. The 12V supply line is completely isolated from the coil and has nothing to do with the coil whatsoever.
The post #53 circuit is designed for the Flame Thrower (1.5 Ohm) coil, as we discussed and as shown on the post #53 schematic.
About the two SMPS units you recommended, one looks like a voltage "step up" and the other a step down. Which is appropriate?
Don't get hung up on the SMPS. As I said, it only provides 12V (at 160 mA) for turning the NMOSFET on and off fast.
By the way, the power supplies linked are not necessarily 'recommended' they are just 'typical examples'. Both SMPS will be acting as step up (boost) converters.
The SMPS of reference (1) of post #53 can only do Voltage step up, while the reference (2) SMPS can do both Voltage step up and step down.
You said "It is definitely not a circuit to build at the moment."
As I said, the circuit of post #53 is an outline to show you the scale of the project. For example the actual NMOSFET is not shown, although I have given a list of likely candidate NMOSFETs both in post #19 and post #58.
The next stage (hard part) would be to do a detailed analysis and optimization of the post #53 circuit, taking into account component tolerances, component stress, reliability, cost, part availability, environment, etc, etc.
What can I do, to push forward the circuit's verification?
You have not answered my question of post #68 about what you want to do. Are you saying that you would like to try out, at risk, one of the Flame Thrower coils.
If so, I can do the next stage of the design and, hopefully, come up with a practical implementation.
But it will cost you a lot of 'Like' votes.
spec
