mikro c button function code is not working
Hi;
i am using four buttons with my PIC16F877A microcontroller. i am using button function if( Button(&PORTD,0,100,0)) in order to detect Logic 0 by a keypress but it is not detecting it. here is my code:
// INPUTS
#define enter PORTD.F0
#define reset PORTD.F1
#define up PORTD.F2
#define down PORTD.F3
//CONSTANTS
#define ms 100   // for button debounce
int scroll_up( int , int );
int scroll_down( int , int );
void main()
    unsigned int i=0;  //i=loops
 // INPUTS:
  TRISD.F0=1;    // ENTER
  TRISD.F1=1;   // RESET
  TRISD.F2=1;    // UP
  TRISD.F3=1;    // DOWN
  TRISA = 0xff;     // port A as input
 while(1)
                    if(Button(&PORTD,0,ms,0))  //when Enter is pressed
                          int itrue=1;
                          x=0;
                          Lcd_Cmd(_LCD_CLEAR);                    // Clear display
                          Lcd_Cmd(_LCD_CURSOR_OFF);
                          Lcd_Out(1,1,CopyConst2Ram(msg,ep));   //enter passward
                          Delay_ms(t);
                             while(Button(&PORTD,0,ms,0)) // press enter
                             {    x++;
                               Lcd_Out(2,x,CopyConst2Ram(msg,asteric));  //*
                                 if(x==4)
                                   Lcd_Cmd(_LCD_MOVE_CURSOR_RIGHT);
                                   Lcd_Out(1,1,CopyConst2Ram(msg,pw));   //please wait
                                   Delay_ms(1000);
                                   Lcd_Out(1,1,CopyConst2Ram(msg,gwt));  // Generator warm up time
                                   inc=0;  //for selection of variable
                                   itrue=1;   // Entring and Exiting main menu
                                   opt=1;    // option b/w selection number or variable
                                             while(itrue)
                                                  if(Button(&PORTD,0,ms,0))  // pressing enter to enter time
                                                   opt=0;
                                                   Lcd_Out(2,1,CopyConst2Ram(msg,sp));
                                                  if(Button(&PORTD,1,ms,0)) //press reset to exit
                                                  itrue=0;
                                                  if(Button(&PORTD,2,ms,0))  //up
                                                  inc=scroll_up(opt,inc);
                                                  if(Button(&PORTD,3,ms,0))   // down
                                                  inc=scroll_down(opt,inc);
                                              x++;
                                 }   //if
                             }    //while
                          Delay_ms(1000);
  }    // while
}      // main
please tell me where i am going wrong in Button function. please don't care of lcd or scroll functions code missing; but i think i am missing some thing in button function. i am just having the problem in button function. my hardware is functioning well, means no problem in there in soldering or wiring connections.
waiting for your kind help, and any help will be much appreciated.
Thanking you in anticipation
Regards
Qaisar Azeemi
The button function above will monitor the PortD.0 with 100ms key debouncing and for the transition for 1-->0.
It is perfectly fine, if what you mean is like above.
acctually when i press the push button my hardware does not detect it........... my hardware is ok... so the problem is in code. should the button function be defined before main function?
Do you have a pullup resistor? Is the PORTD pin set to be an INPUT?
Using a voltmeter, does the voltage on the PIC input pin go from 5v to 0v when the button is pressed?
Answer for all above Questions is ........ YES ......... :)
if((!But1) && (!But2))
what about this? :rolleyes:
Hi ese2709... Its not the reading of the port that Qaisar is having problems with... Its the function supplied by MikroC , There seems to be an internal issue.
Qaisar!! try to mess about with the debounce delay.... Try different values.... the constant "ms" may be causing the problem...
Not required because it is in the library of MikroC.
But yes Ian says may be try to play ms value of debouncing.May be that is causing the problem.
how to declear port D of pic16f877a as input??? kindly guide me about this.... i have decleard it as :
AND
TRISD.F0=1;
IS this a true declearation???
Thank you very much DJ, Ian Rogers and all. the problem was in my software. i have reinstalled the software and the problem is solved:) .. now it is compiling the true hex file. i am again very thankful to you for your kind help :)
