Jon Wilder
Active Member
16F628 MIDI Code Template...Experts Please Review
Hi there...as I'm learning more about the 16F628 I've decided to make a template for coding MIDI stuff that I know will work for MIDI. Was wanting to get a 2nd set of eyes to look it over and maybe offer advice regarding how I can improve on it or if it's fine the way it is. Any and all suggestions from the experts welcome.
This is a pre-canned template for the 16F628 that I wrote and have tested in a MIDI circuit. Just looking for pointers on how I can improve my coding technique in order to keep from becoming what the pros refer to as a "sloppy programmer".
For those of you who are just starting out in the world of MIDI with the 16F628 are more than welcome to use this template. Everything I do with the 16F628 is purely experimental and is considered open source. I plan to graduate to a higher level PIC uC here in the near future so please feel free to use this template for anything MIDI as it has been tested and it does work.
;** MIDI Software Template **
;** With 16F628 PIC Micro **
;** By **
;** Jon Wilder **
;** Processor Config **
processor 16F628
include <P16F628.INC>
__CONFIG 0x3D22 ;disable cp, dcp, lvp, boden, wdt & enable mclre, pwrt, hs osc
; external clock speed = 20MHz
;** Port Initialization **
org 0x00 ;start at address 0
clrf PORTA ;initialize Port A register
clrf PORTB ;initialize Port B register
bsf STATUS,RP0 ;switch to Bank 1
bcf STATUS,RP1 ;switch to Bank 1
movlw B'00000000'
movwf TRISA ;set Port A up as all outputs
movlw B'00000110' ;set Port B up as all outputs
movwf TRISB ;with the exception of RB1/RX and RB2/TX
bcf STATUS,RP0 ;switch to Bank 0
bcf STATUS,RP1 ;switch to Bank 0
movlw 0x07 ;disable on board
movwf CMCON ;comparator
;** USART Initialization **
movlw 0x09 ;set Baud Rate Generator up for
movwf SPBRG ;31,250 baud with 20MHz crystal
bcf TXSTA,SYNC ;enable asynchronous serial comm mode
bsf RCSTA,SPEN ;serial port enable
bsf RCSTA,CREN ;continuous receive enable
;** Program Start **
Main
Program Goes Here
;** Subroutines **
Subroutines go here
End
