Thanks for help, I managed to make as small amount of lines to brake.
As I see it, MS word is program which makes directly a visual printable version, for example A4 format, so if there would be an option to make long unbreakable lines, how would one then print that.
Ahh, time will come, where no more obsolete paper is needed, forest will be grateful too.
Can you post a sample of your code in txt format, just a short snipit. Unless it is proprietary.
Do you mean lines that dont all start with a Capital letter when you press the Enter key.??
Well, I still have not figured this out, but I did notice a difference in a code file that formats well in word and your code. Here is what is found.
With Emeditor I compared character codes.
Good file Char code = U+002F, ANSI 2F
Your File Char code = CR+LF, U=000D, U+000A
Don't know what that means but it is a difference and maybe someone else knows what it means...
Hi Mike,
If the OP can program in say, Visual Basic, he could write his own 'code tidy' like Mike aka Pommie has done for assembler.
Thats what I would do.
