Microcontroller "Mantra"...
UTMonkey
Hi All,
Being a relative newcomer to microntroller programming, I still find the usual things that cause the initial problems in my projects (usually after hours of debugging).
Here's my mantra:-
  1. Check the outputs
  2. Check the inputs
  3. Be sure to disable the A\D stuff if not required.
What do you think? what changes would you make?
Regards
Mark
Don't jump to any conclusions with troubleshooting
Takes small steps, not leaps
Comment Everything
Save every version of every program you write. Back them all up.
Hardware side of things:
Fit only passive and power semiconductors initially, no active elements where possible.
Confirm your application actually matches your design schematic.
Check polarities of all electrolytic capacitors, diodes and other polarity sensitive devices for proper orientation before powering up.
Check for obvious short circuits, especially on power supply rails, clock lines and outputs.
Power up and check your power supply rails and decoupling, if all seems as expected only then power down and fit the remaining semiconductors.
Check the other possible causes of simple troubles, like clocking, don't forget the crystal decoupling caps for example, although that should already have been caught by verifying your implementation.
Check for proper operation of master reset circuitry.
Firmware side of things:
Ensure that the proper device configuration bits are set to perform the functions you require.
Disable any device peripheral or feature that you are not using, do not rely on default power up-reset conditions to perform this, as it may not always work as expected under all circumstances.
Always set your input and output directions, clear junk from output latches and initialise used registers and interrupt flags to a known state.
If using a watchdog timer, ensure your code has a way to handle it in a timely fashion, attempt to find a way to reduce the number of places within your code where the timer is reset, ideally, in only one place, because there is less chance of a runaway process or loop resetting it accidentally.
Check that your program has defined entry and exit points for all interrupts and loops, always make sure your code can return from an interrupt or loop when required to.
Also ensure that you save and restore the status of flags and essential registers used or shared within any interrupt service routine.
Watch your calls and loops for stack overflow problems, especially if using a small or mid range PIC as they have limited stack space and no management features like push/pop.
When using a processor that uses banking and paging, like a PIC for example, ensure that you handle these in a graceful way, always know where your code is executing from.
It's always helpful to flowchart any process, in all but the simplest case, that you are attempting to achieve, it makes the code implementation side easier and highlights potential problems in advance.
Break down complicated processes into smaller, easier dealt with, logical blocks, and thoroughly debug each block of code before moving on.
Document everything that you do, add notes to yourself to help you remember why you done something this way rather than that way.
Always back up your work, never have only one copy of your code, keep one copy for adding new code blocks, and a copy immediately preceding the changes, when you verify that all is working as expected, make that file the back-up.
Always take a back-up whenever you make major revisions to your code.
Store back-ups off the machine you are working on, just in case of a drive failure.
There are loads of approaches to this subject, but this is the general methodology I try to stick to, I say try, because it's much harder to do than say :)
rgds
1. Primary test doing in a trainer board or in a vero board (but not in breadboards)
2. Look into the software & debugging.
Check configuration word first & change OSC type & see. (Because I have found bad crystals)
As 'geko' says.
When all else fails, read the datasheet.:rolleyes:
When writing a program, its a good idea to test and debug each module of the code, before writing the full program.
Buy a training development pcb kit for the PIC that you plan to use, a good starting point are the 18Fxxxx series of PIC's
Bill's kits are well supported.:)
You have not found an unknown bug in the microcontroller, it's in your code, your just haven't looking hard enough yet.
Taking that a step further, if a single function or subroutine is so long you need to scroll up/down the screen to see all the code then it's probably too big and would benefit from being split into two or more functions/subroutines.
Does of course depend on the screen resolution somewhat but I find it's much easier to 'follow the code' and therefore debug when you can see the whole of it on the screen at the same time.
Check everything starting from the power supply. Compulsory. 50 test point check in 50 seconds cause it takes a 1/2 second to move a probe and 1/2 second to verify the levels.
