Menu Names
TucsonDon
I have a sub menu that has 16 items, how do I declare the names as a constant? I have tried the following in the header file but got a lot of errors.
C:
typedef char MENU_NAMES
{"NAME 1"},
{"NAME 2"},
{"NAME 3"}
Normally you setup the arrays thus..
char MENU_NAMES[][] = {"Name 1", "Name 2","Name 3"};
Then usually you can enumerate them to all by name..
enum{
Name1,
Name2,
Name3
Then call them
print(MENU_NAMES[Name1]);
enum{
Name1,
Name2,
Name3
Then call them
Thanks for the info.
I already have the names enumerated for a state machine
C:
tyepdef enum
NAME1_SM,
NAME2_SM,
NAME3_SM
}MENU_NAMES_SM;
Can I use this or do I have to enumerate them again?
Also remember to add const. Below is what you want to do, you can use your enum to reference it, although you don't need to typedef it unless you want that.
const char *menuNames[] = {
        "name1\n",
        "name2\n"
Of course you can...
Most compilers should be smart enough to see fixed text and store to prog mem...
First negative rating ever!!!
Perhaps...but its not hard to add for completeness is it?
There is always a pro and con to doing things one way or another.. Sometimes, if you can afford the memory, its easier than having two print routines... I have to sprintf() to get constant strings to play with ram strings... If only a few text strings are needed, it may consume less ram than using conversion functions...
Haha, sorry Ian, I just simply disagree with your answer, only here of course.
I mean, have you tried to compile that?
Well I thought it wouldn't compile, but to be fair I just tried it and you only need to explicitly set the length:
char MENU_NAMES[][7] = {"Name 1", "Name 2","Name 3"};
I prefer to use an array of pointers as then you can have variable length menu items.
const uint8_t menu1[]="Menu One";
const uint8_t menu2[]="Menu Two";
const uint8_t menu3[]="Menu Three";
const uint8_t menu4[]="Menu Four";
const uint8 *table[]=&menu1,&menu2,&menu3,&menu4;
void test(void){
unsigned char x;
const uint8_t* point;
    point=table[3];  //3 is the menu number - note 0 to 3 - not 1 to 4
    while(*point){   //while not end of string
        x=*point++; //will load all the letters of "Menu Four"
       // call put LCD etc here
In the above just change uint8_t to unsigned char. Or include stdint.
Edit, probably not advised for beginners.
void test(void){
unsigned char x;
This is just a long winded version of my post @ 4.
Apart from the text being allowed to be any length... using pointer arrays allow for "hello!" and "Hello world!" to be used in the same context.. I used this method once years back .. I made a "Hangman" game and when I displayed the amount of characters in the form of asterisk's I used the strlen() function rather than having to have an array of string sizes..
Just to clarify, not sure if that sentence is insinuating/suggesting that it can't, but post 4 method is an array of pointers to constant chars, and can take variable length strings.
On a side note, the OP may want to think about using structures, as it really helps with scaling. For example a 4x16 display.
typedef struct {
    unsigned char index;
    char *line1;
    char *line2;
    char *line3;
    char *line4;
} tmenuStr;
enum {
    MENU_DISP_GREETING,
    MENU_DISP_MENU1,
    MENU_DISP_MENU2
const tmenuStr menuStruct[] = {
    {MENU_DISP_GREETING, "My project here", "Hello World!", "Whatever else", "And more text"},
    {MENU_DISP_MENU1, "Menu1 - line1", "Menu1 - line2", "Menu1 - line3", "Menu1 - line4"},
    {MENU_DISP_MENU2, "Menu2 - line1", "Menu2 - line2", "Menu2 - line3", "Menu2 line four"}
void lcd_output (unsigned char menuPtr) {
    lcd_print(menuStruct[menuPtr].line1);
    lcd_gotoRow2();
    lcd_print(menuStruct[menuPtr].line2);
    lcd_gotoRow3();
    lcd_print(menuStruct[menuPtr].line3);
    lcd_gotoRow4();
    lcd_print(menuStruct[menuPtr].line4);
lcd_output (MENU_DISP_GREETING);
No! Your code is as good as Mikes' I try to stay away from pointers when helping newbies, It's more of a distraction.. I just feel Mikes' code is easier for a newbie to follow.. I think I have tried to go straight into pointers, but without prior knowledge of pointers, the general newbie programmer may start to use uninitialized pointers thinking that its okay to do so...
When I answer on a thread, I try to put myself in their shoes.. I realise that TucsonDon isn't that much of a newbie, but others are following!!
