Sceadwian
Banned
L1 and L2 both provide 120 volts in relation to neutral, the phase relationship between L1 and L2 is 180 degrees. If you don't call that two phase you need your noggin examined. I don't care what's used commonly in electrical distribution that has no bearing on it being a cat, they just skin it a little different =) Technically you'd call it split phase but it's a whole lot of arguing over words. They only reason for the phase order requirement for it to be called polyphase is because of AC motor loads needing a fixed phase order. In a split phase supply an AC motor wouldn't know which direction to turn.
