Measuring negative voltages with a PIC
hi Al,
Try this original circuit [ with the 5.6Vz added]
E.
hi Al,
Did you try setting up the current sensor with the modification.?
Eric.
Sent you a PM
Hi Eric,
Yes mate, that seems to work. But I do have some conversion questions!
I don't understand the .4v offset thing. I have set the circuit to give 2.48v at 1A but then the LCD shows garbage at 0A, I assume its going less than 0.
I remade the OPA circuit to do both current measurements on the same OPA and all seems to work ok apart from the above problem anyway and the fact that I have not found a .5A load yet to set up the variable voltage current sense. I used a car sidelight bulb for the 1A which strangely is almost exactly a 1A draw at 5v. A happy coincidence!
Also I am having a problem with adding! Back to school I think! Seriously though I can't understand how PicBasic uses the DEC function as you will see in my latest thread. Can you simulate this function in Oshonsoft?
It is a real pain burning and swapping Pics just to find its still wrong. Poor manual for PBP in some aspects.
Al
Hi Al,
The 0.4V offset showed up on the Sim, so if you actually get zero ADC counts at 0mA thats fine, forget the 0.4.
At 1Amp, at 2.44V, with the ADC count set to 500, multiply the 500 by 2 to give 1000 counts equal to 1000mA
The rubbish at 0V could be noise or your sums.
At what voltage above zero amps does the reading become steady.???
E.
Hi Eric,
The problem may be something different as when I set the circuit to 2.44 then I have to multiply by 4 to get 1000 as the ADC count is only 250ish. But doing that means its fine at 1A but reads 56 for 16mA.
I must be doing something wrong? But what?
Al
Hi Eric,
Al
hi Al,
You have an error in yours sums.
The 2.44Volts with a 5Vref will give 500 counts in the adc value, you multiply this value by 2. So 500 adc count value times 2 =1000. equivalent to 1000mA
This will enable a mA resolution of 2mA per adc count, which means the next lower current value displayed will be 998 counts * 2= 998 which is 0.998 amps [ its going down in 2mA steps]
So each count of the ADC value = 2mA, if you have a 16mA actual current this means the adc count should be 8..
Working the sums back:
Assume the adc count is 8, then *2 = a value of 16 , which is 16mA or 0.016Amp
If the count increased by 1, to say 9 counts, then *2 = 18 value = 0.018A
If the adc count was only 1 say, then *2 = 2 = 2mA or 0.002A.
If you dont follow, just ask, its no problem.;)
E
Dont multiply the count by 4
Hi Eric,
If I set the OPA to 2.44v out at 1A and then use the ADC on it it shows 500 when multiplied by 2. So do I adjust the OPA to output enough to make the ADC 500 or what else? Really puzzled at this. But thats normal at least. hehehe
EDIT. Is this line doing the damage?
adval = (adval */ 500)>>2 	     ' Equates to: (adval * 500)/1024
Al
Hi Eric,
In truth I don't know why that line is in at all, since I dont understand what it does. Can you explain it?
I picked it up from the PBP examples I think and thought I needed it as they seemed to use it often.
Told you I was getting dimmer!
Al
Hi Eric,
Al
hi Al,
Is adval what you are reading from the PIC's adc .???
If yes, then adval = adval *2 = 1000
That means if adval was 500 say, it will be 1000 after being multiplied by 2, which is 1000mA.
Do you have a command in ProBasic, to send the adval to the display.???
In Oshonsoft I would use LCDOUT = #adval, and that would display 1000
I dont use ProBasic, I will look for free download of their ProBasic commands
E
Hi Eric,
Yes the ADC value is read into adval.
I have just removed the offending line and now things seem better. Thats why all along I have had half ( or roughly) of the numbers I should have. So what is the line for?
I still have a problem with the DEC command I think. My readings fluctuate in value by tens without changing unit values so I must be getting the DEC command wrong somehow.
Al
Have you tried LCDOUT #adval without the DEC.
The way I read the manual is that DEC is used to Format the display data. According to the manual the LCDOUT #adval will display the actual count value.
That should give you a direct reading of the milli-amps 0 thru 1000mA.
If that is steady it will prove that the ADC and display is working OK and the jumping problem is caused by the way you are using the DEC statement.
I am trying to get a PICBasic tutorial download.
E.
EDIT:
Look at the LCD section of this tutorial
https://melabs.com/resources/pbpmanual/5_32-5_35.htm
Morning Al,
I have converted your posted PBP program to Oshonsoft Basic so that I can follow what you are doing.
This is what I have so far, no formatting at the moment.
Will post post more as I progress.
E.
EDIT:
Deleted , incorrect wiring on my part !! duh!!
mainloop:
Gosub getposval 'Get + value
Gosub getnegval 'Get - value
Gosub getfive 'Get 5v rail amps
Gosub getvaramp 'Get variable amps
Case 2
Goto amps
amps:
If five > 1023 Then five = 0
If five < 0 Then five = 0
Lcdcmdout LcdLine1Home
Lcdout "+5 Rail = ", #five ''dec(five * 4 - 40), "mA" 'Display the decimal value
Lcdcmdout LcdLine2Home
Lcdout "Var Rail = ", #five ''dec(varamp * 4 - 40), "mA" 'Display the decimal value
WaitMs 200 ''pause 200
Goto mainloop
Hi Eric,
I have sorted the problem with the displays jumping in tens by using dec3 instead of dec2 after the decimal point.
Now even the maths add up. Though I have done this I still do not understand what the dec function does! Nowhere does it explain what the number ater dec does. Now I have the correct readings but I also have 3 digits after the decimal point instead of 2 and the 3rd one is such a small value that it fluctuates all the time.
I didn't need the 3 places but it seems that I can't have the correct results without it!
Also at the moment I have got a problem with reading the var rail. It has no volts coming out of the OPA ciruit and I don't know why! I have looked at it half a dozen times now and see nothing amiss. May be better to start again with the OPA circuit board? Do OPAs fail on one side very often?
Al
Hi Al,
Chan 4 is not set as ADC its Digital!.
Look at this image.
E.
Hi Eric,
I followed the datasheet for the 872 and it does say that the first 4 "As are 0,1,2,3 channels then the last AD channel is "A5 missing out RA4.
I think I got the hex numbers right s0 ADC1 = $41, 1 = $49, 2 = $51, 3 = $59 and 4 = $61 though I wasn't sure if the last one should be $69 even though that would be RA5 I understood it that they didn't count RA4 at all?
How do you read it?
BTW I have got the thermal sensor wired as you showed with the linearisation and the output is definately better but my reading fluctuates wildly. It is roughly right sometimes maybe showing 22 when it should be 21 but flicks from 22 to 16 to 4 etc, the only way of actually telling is that the 22 is more prevellant.
Al
hi Al,
Look at this modification to the program
Dim temp As Word
TRISC = %00001111
TRISA = %00111111
ADCON1 = %10000000 'Set PortA to A/D inputs
I am trying to get the ADC's working just to display the actual ADC count, it seems to be working OK.
How far have you got.?
E.
EDIT:
Image of Therm, no formatting, yet
Hi Eric,
How do you read it?
Al
hi Al,
These are the ADC addresses [ dont mult the adcval * 2 in the getad subr]
I am assuming that:
posval is 4.88V at 15V out
negval is 4.88V at -15V out
getfive is 2.44V at 1Amp out
getvaramp is 2.44V at 1Amp out
Dont know your temperature volts or range.??
Can you confirm.?
I will explain the 'DEC' formatting when we sort out the ADC's
E.
'Subroutine to get pot x value
getposval:
ADCON0 = 41h  'Set A/D to Fosc/8, AN0, On
Gosub getad
posval = adval
Return
'Subroutine to get pot negval value
getnegval:
ADCON0 = 49h  'Set A/D to Fosc/8, AN1, On
Gosub getad
negval = adval
Return
'Subroutine to get 5v current value
getfive:
ADCON0 = 51h  'Set A/D to Fosc/8, AN2, On
Gosub getad
five = adval
Return
'Subroutine to get variable amps value
getvaramp:
ADCON0 = 59h  ''61h  'Set A/D to Fosc/8, AN3, On
Gosub getad
varamp = adval
Return
'Subroutine to get temperature value
gettherm:
ADCON0 = 61h  'Set A/D to Fosc/8, AN4, On
Gosub getad
therm = adval
Return
getad:
WaitUs 50  ''pauseus 50                      ' Wait for A/D channel acquisition time
ADCON0.2 = 1  'Start conversion
While ADCON0.2
Wend  'Wait for it to complete
adval.HB = ADRESH  'Write conversion result
adval.LB = ADRESL
'''adval = adval * 2
WaitMs 2  ''pause 2
Return
Hi Eric,
Yes all your assumptions are correct except that the varamp would be 2.44 at 500mA since the PSU is only rated at 500mA for that rail. But it is a moot point at the moment since I can't get the varamp side of the OPA to do anything at the moment.
My temp sensor is set up as per the diagram you posted with +5v to sensor pos and a 10k from sensor neg to gnd. there is a 56k resistor in parallel with the sensor and the output if from the junction of the 10k and sensor neg.
With that setup I get an ADC of 354 at 0c and 933 at 100c.
Now the maths, I took 354 from 933 to give a 100 degree scale of 579 so 1 degree is 579/100 = 5.79?
Then I take the ADC and subtract 354 and multiply the remainder by 5.79 well 579 and divide by 1000 to get result?
Am I on the right track?
Al
Hang on I got confused. I meant get ADC value and subtract 354 then divide by 5.79, I think!
But it still gives weird results, certainly not the results I get by using the calculator.
Al
