MCLR, Pull-up,Pull-down with ICD2 clone
GRC
Hey gang
Tell me if this sounds odd. When using an ICD2 clone, the device programs
and erases much more reliably when a 10K ohm resistor is connected to VSS
and the PIC's MCLR pin(Pull-down). However when the PIC is not connected
to the ICD2 clone and is running on its own the the 10k ohm resistor needs
to be connected to VDD and the PIC's MCLR pin(Pulled-up).
Does this seem funny to you also.
Yes, with an ICD2 clone there are three possible states for MCLR:
1) 0V - device in reset.
2) 5V - device running.
3) 13V - device in programming mode.
I suspect you have a problem somewhere?.
Thanks for the reply Nigel.
I believe I understand what your saying.
By the way I started working my way through some of
your tutorials(well loosely anyway) using the 16F88.
