MCC18 Driving me crazy
AtomSoft
Ok for some reason i keep getting a halt on my second delay
  	#pragma	config OSC=INTIO2, WDT=OFF, LVP=OFF, DEBUG=ON
  	#include <p18f1320.h>
	void InterruptHandlerHigh(void);
	void InterruptVectorHigh(void);
	void MyDelay(int x);
	void MyFlash(int qTimes);
void main(void)
	int count;
	int countA = 0;
    ADCON1 = 0; // make RA0 digital
    TRISA = 0b10111110;
    while(1)    // loop forever
      	LATA=0b00000001; // Turn LED on
		MyDelay(200);
      	LATA=0b00000000; // Turn LED off
[b]      	MyDelay(200);     // The program halts here. Any thoughts?[/b]
		countA = countA + 1;
		if (countA > 3) {
			MyFlash(3);
			countA = 0;
void MyDelay(int xD)
		int countD = 0;
		while (countD < xD)
        	countD = countD + 1;
void MyFlash (int qTimes)
		int x = qTimes;
		while(x != 0)  {
			TRISA = 0b10111110;
			LATA = 0b00000001;
			MyDelay(10);
			LATA = 0b01000000;
			MyDelay(10);
			TRISA = 0b00111111;
			LATA = 0b01000000;
			MyDelay(10);
			LATA = 0b10000000;
			MyDelay(10);
			TRISA = 0b01111110;
			LATA = 0b10000000;
			MyDelay(10);
			LATA = 0b00000001;
			MyDelay(10);
			x--;
		TRISA = 0b10111110;
// High priority interrupt vector
#pragma code InterruptVectorHigh = 0x08
void InterruptVectorHigh (void)
  _asm
    goto InterruptHandlerHigh //jump to interrupt routine
  _endasm
// High priority interrupt routine
#pragma code
#pragma interrupt InterruptHandlerHigh
void InterruptHandlerHigh ()
	int countF;
	if (INTCONbits.RBIF) {
	INTCONbits.RBIF = 0;            //clear interrupt flag
	countF = 15;
	INTCON3 = 0;
 	MyFlash(20);
in the "c012i.c" file it points to:
  _asm
    // Initialize the stack pointer
[b]    lfsr 1, _stack  // Points here[/b]
    lfsr 2, _stack
    clrf TBLPTRU, 0 // 1st silicon doesn't do this on POR
    bcf __FPFLAGS,RND,0 // Initialize rounding flag for floating point libs
    _endasm
I posted a reply to this thread but it seems to have got lost.
I asked, what happens if you cut it down to it's absolute minimum. The smaller the code the easier to identify the problem.
This
		int countD = 0;
		while (countD < xD)
is horrible! Do this instead
	int countD = 0;
	while (countD < xD)
You're still mixing spaces and tabs, and your indentation is all over the place. Neat, correct indentation makes things so much more understandable.
These
shouldn't be indented at all.
AtomSoft said:
ok lol i usually dont worry about spacing till finished thats all
Hehehe :D Like code commenting, indentation, if left till the end, never gets done. Six months later you'll try to read your messy code and you'll kick yourself for not making it more readable. :) At this point your code is still small. Wait till it starts getting BIG. If you aren't organized you're lost.
i think something is wrong with my junebug buttons. I just slightly touch not press a button and it goes off. Eveything seems to work fine except that.
Is this neater i tried my best lol
My code:
void main(void)
	int count;
	char countA = 0;
	TRISA = 0b10111110;
	INTCON = 0b11011000;
	INTCON2 = 0b11110000;
	INTCON3 = 0;
		MyDelay(200);
		MyDelay(200);
		if (countA > 3) {
			MyFlash(3);
			countA = 0;
	int countD = 0;
	while (countD < xD)
	int x = qTimes;
	while(x != 0)
		TRISA = 0b10111110;
		LATA = 0b00000001;
		MyDelay(10);
		LATA = 0b01000000;
		MyDelay(10);
		TRISA = 0b00111111;
		LATA = 0b01000000;
		MyDelay(10);
		LATA = 0b10000000;
		MyDelay(10);
		TRISA = 0b01111110;
		LATA = 0b10000000;
		MyDelay(10);
		LATA = 0b00000001;
		MyDelay(10);
		x--;
	TRISA = 0b10111110;
	_asm
	_endasm
#pragma code
		INTCONbits.INT0IF = 0;
		MyFlash(10);
Only a tiny bit. You're still all over the place. Ah well, you'll improve with practice... maybe.
Sounds like you've got some pins floating.
Ok i found the floating pin and it was PORTB7 which calls a interrupt everytime i was my have over the board lol but when i set it in TRISB to 0 i get NO interrupts. I went over it like 20 times changing things but no luck plz any info.. thx
void main(void)
	int count;
	char countA = 0;
	TRISA = 0b10111110;
	TRISB = 0x00000001;
	LATB = 0;
	INTCON = 0b11001000;  //11011000;
	INTCON2 = 0b11110101; //10000001
	INTCON3 = 0b11001000;
		MyDelay(200);
		MyDelay(200);
		//if (countA > 3) {
		//	MyFlash(3);
		//	countA = 0;
	int countD = 0;
	while (countD < xD)
	int x = qTimes;
	while(x != 0)
		TRISA = 0b10111110;
		LATA = 0b00000001;
		MyDelay(10);
		LATA = 0b01000000;
		MyDelay(10);
		TRISA = 0b00111111;
		LATA = 0b01000000;
		MyDelay(10);
		LATA = 0b10000000;
		MyDelay(10);
		TRISA = 0b01111110;
		LATA = 0b10000000;
		MyDelay(10);
		LATA = 0b00000001;
		MyDelay(10);
		x--;
	TRISA = 0b10111110;
	_asm
	_endasm
#pragma code
void InterruptHandlerHigh () [b]//I have a breakpoint here[/b]
		MyFlash(1);
INTCON2 controls the RBPU (weak pullup) it has to be set to zero to enable it. Just enable it and leave it enabled. No need to turn it off.
[FONT=Crystal, monospace]INTCON2bits.RBPU=0;  // enable weak pullups on PORTB input pins[/FONT]
I'm starting to like C18 :)
Still a no go. Im going over every line but am dieing here lol I set trisb 7 and i get no breakpoints dont and i get that 1 breakpoint. I took the interrupt code from the C18 User Guide
New code
void main(void);
//void MyInterr(void);
//void InterruptVectorHigh(void);
//void InterruptHandlerHigh(void);
void interrupt_at_high_vector(void);
void high_isr (void);
void main(void)
	int count;
	char countA = 0;
	TRISA = 0b10111110;
	TRISB = 0x00000001;
	LATB = 0;
	INTCON = 0b11010000;  //11011000;
	INTCON2bits.RBPU=0;
		MyDelay(200);
		MyDelay(200);
		//if (countA > 3) {
		//	MyFlash(3);
		//	countA = 0;
	int countD = 0;
	while (countD < xD)
	int x = qTimes;
	while(x != 0)
		TRISA = 0b10111110;
		LATA = 0b00000001;
		MyDelay(10);
		LATA = 0b01000000;
		MyDelay(10);
		TRISA = 0b00111111;
		LATA = 0b01000000;
		MyDelay(10);
		LATA = 0b10000000;
		MyDelay(10);
		TRISA = 0b01111110;
		LATA = 0b10000000;
		MyDelay(10);
		LATA = 0b00000001;
		MyDelay(10);
		x--;
	TRISA = 0b10111110;
#pragma code high_vector=0x08
_asm GOTO high_isr _endasm     [b]//   brakpoint here [/b]
#pragma code /* return to the default code section */
#pragma interrupt high_isr
I cut it down to a bare minimum and still no good:
void main(void)
	INTCON2bits.RBPU=0;
	INTCON2bits.RBIP=1;
	INTCON = 0b11010000; //[b] Setting Bit 3 to 1 gives a automatic interrupt [/b]
	TRISB = 0b00000001;
	while(1){
_asm GOTO high_isr _endasm     //   brakpoint here
	INTCONbits.INT0IE=0;
