epilot said:
ok, i have buld the second circuit and it seems it works(i can see amplitude exchanges onmy oscope with modulated signal as input and a 40kHz square carrier wave generated with a 555 ic)
anyway i have a square wave in the output(hope it works instead of a sine wave)
ok i think you want me to removecarrier and one sideband in the reciever, and use from a DSB for the transmitter, is this correct?
Nigel, i think it is possible making a SSB using only one high or low pass filter, if so,why you are saying that "is a VERY different technique"?
For SSB you remove the carrier and modulating frequencies (using a double-balanced mixer - like you have). This leaves the upper and lower sidebands, either of which carries all the information you want. So you remove one of them using a very sharp, narrow-band, filter - it's common to do this at 9MHz, and crystal filters are available for this exact purpose.
At the receive side, because it's no longer AM, you have to reinsert the carrier, and also try and make sure it's EXACTLY the same frequency as the original, or the voice will be the wrong pitch. If you reinsert the carrier the wrong side of the sideband you get a completely unintelligible voice - sort of inside out?, mirror image?, which makes quite an interesting scrambler system.
Bandwidth is poor, quality is poor, but it has the advantage that you don't waste transmitter power sending parts you don't need - which is why it's used for long range radio communication. Only CW (morse code) goes further.
As you already have severe quality limitations, the last thing you want to do is cripple it further, which will also add complications and not really help anything.
As you've said 'AM' all along, I would suggest you stick to proper AM, it's the best 'quality' option of the three low quality modes you've mentioned.
i want to amplify the output of 1496, this means i want to amplify the AM signal, i want to use from an amplifier IC ans since i have some of LM3875(it can Handle more than 50W)i want to use them, what is your idea?
i connect the input of amplifier IC to output of 1496 IC and the ouput of amplifier goes to ultrasonic transmitter,is this a good idea to improve the output of 1496 IC?
You don't really need a lot of 'power', you can feed ultrasonic just from a single transistor if you want - depending on the supply voltage you use. If your supply is only low, using a bridged output stage will give twice the voltage swing.
But for a start I would forget the transducers altogether - connect the output of your modulator to the input of your de-modulator, see how it works, and what quality you get. Obviously the transducers will reduce quality further, but I suspect it won't be great even direct?.
What are you using for a de-modulator anyway?.
