Making a PIC Dice for grandson but small problem
bigal_scorpio
Active Member
Hi to all,
I was planning on making a PIC Dice for my young grandson and found a program that looks just the job.
Unfortunately its for the PIC12F675 and I only have some PIC12F629s.
The datasheet covers both PICs and the only difference I can see is the 629 not having any Analog capacity where as the 675 does.
Would this program work on the 629? Because its in ASM I can't figure out what does what. I only know Basic so could anyone out there check the code and see if anything needs changing please.
Thanks for looking.........Al
; Electronic Die
; Pete Griffiths,  17 May 2004
; email: picdie@petesworld.demon.co.uk
; Copyright Pete Griffiths 2004
; This program is free software; you can redistribute
; it and/or modify it under the terms of the GNU
; General Public License version 2 as published by
; the Free Software Foundation
; Use PIC type 12F675 with internal 4Mhz clock
	#include	"P12F675.INC"
; You must preserve the OSCCAL data in the destination device
; before writing this code to it.
; Set config register for:
;  Code / Memory protection off
;  Brown-out detect off
;  MCLR disabled (use pin for IO)
;  Watch Dog timer disabled
;  Power on reset delay enabled
;  Enable Internal Clock Osc, (set pins for IO)
	__CONFIG   _CPD_OFF & _CP_OFF & _BODEN_OFF  & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
;	Equates and Variables
	cblock	0x20
		dtime	;delay sub
		ltime	;delay sub
		rollCnt	;pseudo roll
		dieNum	;pseudo roll
		throw	;actual throw num
		blankto	;blank time out count
	endc
; Point reset vector to program start
	org	0x00
	nop
	nop
	goto	_main
; SUBROUTINE
; Lookup Table for GPIO Port Display Data
; Lookup table takes value in W and returns with
; port data for die in W
; Output low = LED on, high = LED off since PIC can sink
; 25mA but only source 20mA.
; As the 12F675 GPIO 3 port can only be configured as an input
; the LEDs connect to GPIO ports 0,1,2 and 4
; where A=GPIO 0, B=1, C=2 and D=4. Arrange LEDs as shown below.
; For 3-4.5v supply, use 270R resistors between each LED and Vdd
; B    C
; D A D
; C    B
_lookup	addwf	PCL,F	;Add W to PCL for computed goto.
	nop		; This needed because we enter with
			; 1 =< W =< 6 and table reads with 0 offset
		; DxBCA
	retlw	b'10110'	;die 1
	retlw	b'10101'	;die 2
	retlw	b'10010'	;die 3
	retlw	b'10001'	;die 4
	retlw	b'10000'	;die 5
	retlw	b'00001'	;die 6
; Subroutine
; Accurate delay routines
; Two routines. Both called with required delay period in W
; One has delay of W x 1mS. Other has delay of W x 100mS
; Accurate for 4Mhz clock
_Delay	movwf	dtime	; Call for W x 1mS
__Dcall	call	__1mS
	decfsz	dtime,F
	goto	__Dcall
__DlyEnd	return
_LDelay	movwf	ltime	; Call for W x 100mS
__Dlcall	movlw	d'100'
	call	_Delay
	decfsz	ltime,F
	goto	__Dlcall
	return
__1mS	movlw	0xC6
_next	nop
	addlw	0xFF
	btfss	STATUS,Z
	goto	_next
	nop
	nop
	nop
	return
; SUBROUTINE
; Displays a rolling die thats starts fast and slows to
; a stop about 3 seconds after SW1 released.
_roller	movlw	0x30	; must be even number
	movwf	rollCnt
_rsetone	clrf	dieNum
_rloop	incf	dieNum,F
	movf	dieNum,W
	sublw	0x07
	btfsc	STATUS,Z
	goto 	_rsetone
	movf	dieNum,W
	call	_lookup
	movwf	GPIO
	movf	rollCnt,W
	call	_Delay
	incf	rollCnt,F
	incf	rollCnt,F
	movf	rollCnt,W
	sublw	0x80	; must be an even number
	btfss	STATUS,Z	; or it never breaks out of the loop
	goto	_rloop
	return
; Entry point for program from Reset
; Initialise GPIO 5,3 input, 4,2,1,0 outputs
; Set GPIO to digital IO
; Set INTCON register for interupt on GPIO 5 change
; disable Global interupts so it wakes from sleep
; but doesn't service interupt.
; Enable weak pull up on GPIO5 input.
; set outputs to high so LEDs are off
_intvect
_main
	bcf	STATUS,RP0     		; Sel Bank 0
	movlw	0x07		;
	movwf	CMCON		; Disable Analogue on GPIO pins
	movlw	b'00001001'	               ;
	movwf	INTCON		; Enable GPIO state change int
				; See 12F675 data sheet P19
	bsf	STATUS,RP0     		; Sel Bank 1
	call	0x3FF		; calls RETLW with factory setting
	movwf	OSCCAL		; Set int OSC to factory calibrated
	clrf	ANSEL		; Disable Analogue on GPIO pins
	movlw	b'11101000'    		; Specifiy GPIO port direction
	movwf	TRISIO		; Set GPIO ports as xxIOIOOO
	bcf	OPTION_REG,NOT_GPPU	; enable weak pull-up
	bsf	WPU, 5		; enable wpu on GPIO 5 only
	bsf	IOC, 5		; enable Int-On-Change GPIO 5
	movlw       0x20			; set up 20mS wait
	call        _Delay			; after reset
; put PIC to sleep and wake on SW1 / GPIO 5
; then 'throw' die
; port GPIO 5 uses internal weak pull up with SW1 n/o to ground.
; Uses interupt on change to wake PIC
_sleepsw1	movf	GPIO,W	; Read GPIO clears Int-On-Change flag
			; must read into W not back to F
			; as it reads port not the output latch
			; which may result in output data being
			; inadvertently altered
			; see 12F675 data sheet, P19 Section 3.1
	bcf	INTCON,GPIF
	bsf	STATUS,RP0	; Sel bank 1
	movlw	0xFF	; Setup W for TRISIO all input
	movwf	TRISIO	; Write to TRISIO. Reduce power in sleep mode
	sleep		; Go to sleep
	nop		;
	movlw	b'11101000'	; Wake from sleep and  set
	movwf	TRISIO	; TRISIO for correct input and output
	movf	GPIO,W	; Read GPIO register
	bcf	INTCON,GPIF	; and clear GPIF flag in interrupt register.
	movlw	d'5'	; load W with 5 (5mS)
	call	_Delay	; and call delay to debounce switch down.
; once PIC wakes from sleep the throw counter
; runs while SW1 is held down
; Given the 4Mhz clock speed of the PIC this results in a
; fairly random number being generated
; Turn of LEDs while SW1 is down
_throwdie 	 movlw	0x17       	; Turn off LEDs while counting
         	 movwf	GPIO
       	 clrf	throw	; Reset throw to 0 for each new throw.
; Number of instruction cycles per loop for this block is 12. Code _evenup wastes cycles to
; ensure that the same number of cycles elapse between checks of the SW1 switch so that
; there is an equal probability of it being released on any value of throw count.
; Block will loop 83,333 times per second with 4Mhz clock (1uS) instruction cycle
; or 833 times in 10mS. Since the throw is determined by the length of time the SW1 switch
; is held down, it results in a fairly even distribution of numbers. Tested with 500
; consecutive throws gave a mean value of 3.492.
_loop	incf	throw,F	; add 1 to throw		#1
	movf	throw,W	; get throw and put in W	#1
	xorlw	7	; compare to 7		#1
			; (result is only 0 when both No's equal)
	btfss	STATUS,Z	; if less than 7 	 #1 or #2 if Z=1
	goto 	_evenup	; go to _evenup	 #2 only for Z=0
	clrf	throw	; else set throw	 #1 Z=1
	incf	throw,F	; count back to 1	 #1 Z=1
	goto	_sw1down	; and goto sw1 check	 #2 Z=1
_evenup	nop		; This is here to even out the	#1 Z=0
	nop		; number of instructions executed	#1 Z=0
	nop		; when throw count isn't reset to 1 #1 Z=0
_sw1down	btfss	GPIO,5	; Is SW1 down?		#1
	goto	_loop	; keep counting if it is	#2
			; we don't debounce the swich because
			; any bounce just helps to make it
			; more random
; switch released
; call rolling subroutine
; then display the thrown number on the LEDs
         	call 	_roller	; Switch has been released so call rolling die sub
	movf	throw,W	; Finished rolling it so get throw value
	call 	_lookup	; call display data lookup
	movwf	GPIO	; and display the throw on the LEDs
; display thrown number for 20 seconds
; then blank display to save battery
; and go back to sleep awaiting next 'throw'
; checks for SW1 throw while displaying previous throw
; in which case it throws again without sleeping.
	movlw	0xD0	; Set count for 20 second display timeout
	movwf	blankto	; move to working file register
_blankdly	movlw	0x01	; call delay subroutine
	call	_LDelay	; with W = 100mS
	btfss	GPIO,5	; on return check if SW1 has been pressed
	goto	_throwdie	; if it has, goto the main throw code
	decfsz	blankto,F	; otherwise decrement display timeout
	goto	_blankdly 	; and carry on with the timeout count
; the fadeout section of code causes the LEDs to fade down at the end of the
; 20 second timeout period.  This uses a single count value for the fadeout period
; and this is used to control the on/off duty cycle of the LEDs as they fade down
; so the period remains constant but the on/off ratio goes from 99/1 -> 1/99
_fadeout	movlw	0xFE	; Set length of fadeout period > = longer
	movwf	blankto	; but don't set to 0xFF
_fading	movf	throw,w	; get last throw number
	call	_lookup	; find LED data for throw number
	movwf	GPIO	; display throw
	movf	blankto,W	; get value in blankto, put in W
	call	_fadelay	; and call fade delay subroutine
	movlw	0x17	; set data for all LEDs off in W
	movwf	GPIO	; write to LEDS
	comf	blankto,W	; complement blankto and put in W
	call	_fadelay	; and call fade delay routine
	decfsz	blankto,F	; -1 from blankto
	goto	_fading	; keep fading until it reaches 0
	goto	_sleepsw1	; goto sleep.
; Subroutine
; used by fadeout to give slow fade of LEDs before
; sleeping
_fadelay	movwf	dtime	; Enter with W set to outer loop count so save this
_fouter	btfss	GPIO,5	; check if SW1 has been pressed
	movlw	0x16	; Inner loop count
	movwf	ltime
_finner	decfsz	ltime,F
	goto	_finner
	decfsz	dtime,F
	goto	_fouter
	return
	dt	" Electronic Die for 12F675 - Pete Griffiths 2004. R6.17052004"
	end
If what you say is true; PIC12F675 almost equals PIC12F629, I did not check, then:
Change the #include line and compile. See what errors you get. If no errors then go for it.
The include file describes the part. You could compare the two files.
Have a look at this extract from the code:
_intvect
_main
	movlw	0x07		;
	movwf	CMCON		[COLOR="blue"]; Disable Analogue on GPIO pins[/COLOR]
	movlw	b'00001001'	               ;
	clrf	ANSEL		[COLOR="blue"]; Disable Analogue on GPIO pins[/COLOR]
As micker just posted above the analogue commands aren't needed so the
movlw 0x07
mowf CMON
and the
clrf ANSEL
can be deleted and the code should program fine.
Regards Bryan
Hi guys,
Cheers for that confirmation, I will give it a go. I assumed it would be something analog but not knowing any ASM I didn't want to cause mayhem. hehehe
Thanks again guys and I will post how it goes........Al
Hi again Guys,
Its a no go i'm afraid even with the suggested deletions and changing the include to 629.
Just loads of errors and I can't find the error log to look at them! Can someone try to compile for 629 please and let me know whats happening?
BTW I'm using MPASMWIN520 to compile - is that right?
Thanks Al
Hi again Guys,
Thanks Al
hi Al,
Can you post the latest program you are trying, I will assemble it for you.
Eric
View attachment PIC12F675_Dice.HEX
I haven't tested it, as I have to pop out shortly, but it has the analogue lines commented out and the #include changed to a '629.
Only messages reported are the usual bank warnings.
Hi Eric,
Thanks mate, that would at least give us an idea if its just me. (probably is, dafter every day) ;)
Here is the code.
; Electronic Die
; email: [email]picdie@petesworld.demon.co.uk[/email]
	#include	"P12F629.INC"
	cblock	0x20
		dtime	;delay sub
		ltime	;delay sub
		dieNum	;pseudo roll
	endc
	org	0x00
	nop
	nop
	goto	_main
; SUBROUTINE
; B    C
; D A D
; C    B
		; DxBCA
; Subroutine
__Dcall	call	__1mS
	decfsz	dtime,F
	goto	__Dcall
__DlyEnd	return
	call	_Delay
	decfsz	ltime,F
	goto	__Dlcall
	return
__1mS	movlw	0xC6
_next	nop
	addlw	0xFF
	btfss	STATUS,Z
	goto	_next
	nop
	nop
	nop
	return
; SUBROUTINE
	movwf	rollCnt
	movf	dieNum,W
	sublw	0x07
	btfsc	STATUS,Z
	goto 	_rsetone
	movf	dieNum,W
	call	_lookup
	movwf	GPIO
	movf	rollCnt,W
	call	_Delay
	incf	rollCnt,F
	incf	rollCnt,F
	movf	rollCnt,W
	goto	_rloop
	return
_intvect
_main
	movlw	b'00001001'	               ;
; then 'throw' die
	bcf	INTCON,GPIF
	sleep		; Go to sleep
	nop		;
         	 movwf	GPIO
			; more random
; switch released
; Subroutine
; sleeping
	movwf	ltime
	goto	_finner
	decfsz	dtime,F
	goto	_fouter
	return
	end
The file now assembles OK in Oshonsoft [MPLAB] , see the files.
  • ALdice1.asm
  • ALdice1.hex
Thanks Guys,
Mickster, your hex worked fine! :)
Eric, so does yours, AND I can assemble your asm file without errors! But WHY?
Why do I get all the errors and you don't? What am I doing wrong? Eric I noticed you ;; out the lines but should that not be the same as when I deleted them? Baffled but grateful.
Thanks again Al
Thanks Guys,
Thanks again Al
hi Al,
When you say 'errors' I think you may mean 'warnings'.
for example.
list p=12f629
errorlevel -302, -207 ------------- without this line you will get
Message[302] C:\00000000.ASM 160 : Register in operand not in bank 0. Ensure that bank bits are correct.
for every instance in your program
The #include "P12F629.INC" is essential, the list p is a listing, just for the programmer to see.
Try to REM out the error level -302 ,-207 and see what get when you assemble.
Hi Eric,
No, I don't think the errors are the same as you thought, here is the screen grab, have a look.
Mine does not assemble at all, but yours does fine. Still baffled
Al
For that many errors the compiler / assembler can't find the "p12f629.inc" file. Look at the actual errors, if the first error is "can't find p12f629.inc" then all the errors will be related to that!
Cheers Ian
Cheers Ian
Hi mate,
Can't get as far as an error file. Its not creating one.
Al
Ahhh! If there is no error.log in the working directory then the output path is incorrect OR the error reporting is turned off. Find MPASMv5.20 and run it (you can assemble directly from within by browsing the file) then you can set all options required on the interface.
Cheers Ian
Why not install MPLABIDE 8.60 ?
hi Al.
How are you running the MPASM.??
You should see an options window./
As suggested by Ian, the quick/long term fix would be to download the MPLAB IDE, its free from microchip.
Thanks guys,
I will download MPLAB IDE and give it a try, then report back.
Thanks again Al
Hi Al,
when you have MPLAB IDE installed successfully, you can find MPASMWIN.EXE in the following location: (Assuming you installed using the default paths)
C:\
Program Files
Microchip
MPASM Suite
All the .INC files are in there as well.
Create a shortcut to MPASMWIN.EXE and drag it to your desktop, or another folder if you don't want a messy desktop like mine, then you can simply assemble a .hex without having to load MPLAB IDE, by simply using the shortcut instead of opening MPLAB and creating a new project, then adding the necessary files.
Quite handy for when you have downloaded a working .asm file and just need to assemble it to produce a .hex file.
HTH.
@Eric Gibbs:
When running files for 12F6XX PICs in Oshonsoft, do you REM ( ; )/delete the following lines;
bsf STATUS,RP0
call 0x3FF
movwf OSCCAL
...and re-assemble, or do you know of a workaround which doesn't require this?
Thanks.
@Eric Gibbs:
bsf STATUS,RP0
call 0x3FF
movwf OSCCAL
Thanks.
Hi Mick,
I have to REM out the 'call 0x3FF and movwf OSCCAL'.
Also the SLEEP.
Eric
