mach3
betazen
Hello. Iam betazen new comer inthis forum.
Ihave problem for mach3 controller 3 axis. Mc cant run. Please inform to me how to troubleshooting/how to check mach3 control.
Thank you
As far as I can tell "mach3" is software.
We may need some more info to help you.
I am also a beginner with MACH3 machine control software. But let us try to make progress.
Mc cant run.
I assume that you mean that the machine does not run, do not use undefined abbreviations.
Is the MACH3 software correctly installed?
Has this system worked before?
Do you have power to the axis controllers?
Is the Emergency Stop clear and reset?
Assuming that this is a conventional milling machine, is the table clear of the end stops and limit switches?
Apart from that I have no more ideas.
This the first time I handle mc with mach 3 control (mill mc). Usualy I handle cnc mc (mitsubishi or fanuc control).
Emergency already release and reset. But axis still not active and spindle is same problem.
What can I do for solve this problem
