LPC2103 UART0 Interrupt
AtomSoft
Ok im having some trouble but not where you would think...
I want to use interrupt to capture incoming UART data. The issue is the data isnt correct.
void InitPLL(void)
  PLLCFG=0x44;
  PLLCON=0x1;
  PLLFEED=0xAA;
  PLLFEED=0x55;
  APBDIV = 0x01;
  while(!(PLLSTAT & 0x400)){}  ;
  PLLCON=0x3;
  PLLFEED=0xAA;
  PLLFEED=0x55;
void Init_UART (void)
    int Div;
    /* Initialize Pin Select Block for Tx and Rx */
    PINSEL0=0x5;
    /* Enable FIFO's and reset them */
    U0FCR=0x7;
    /* Set DLAB and word length set to 8bits */
    U0LCR = 0x83;
    /* Baud rate set to 19200 */
    Div = (60000000/16)/19200;
    U0DLM = Div/256;
    U0DLL = Div %256;
     /* Clear DLAB */
    U0LCR = 0x03;
    U0IER = 0x03; //RDA
    //Interrupt Setup
    VICIntEnClr     = 0xFFFFFFFF; //Disable all interrupts
    VICIntSelect = 0x00; //UART0 = IRQ Interrupt
    VICVectCntl0 = 0x26; // Vector 0 is for UART0 and is Enabled
    VICVectAddr0 = (unsigned long)UART0_ISR; //Prototype address to be called
    VICIntEnable = 0x40; //Enable UART0 Interrupt
void UART0_ISR(void)
    unsigned char temp = U0RBR;
    VICSoftIntClear = 0x40; //Clear Interrupt
    VICVectAddr=0xFF;
example 1: if i send a 0x31(aka 1 key) to the MCU it shows 0x99 as the input.
example 2: if i send a 0x32(aka 2 key) to the MCU it shows 0x9A as the input.
What can be wrong ?
MCU is running at 60Mhz, BAUD RATE is 19200. Help Please.
